Question about Epson Stylus CX6000 All-In-One InkJet Printer
Printer will not feed paper correctly
The paper starts to feed then it gets pulled in on the right side and the left side does not feed in. I get an error E-90 then a clear paper jam E-04 - there is not a paper jam?
  • 1 more comment
  • KLD2 Jan 22, 2009
    my printer does the exact same thing, pulls to the right but not to the left. We are not the only ones with this issue...I think it's a chronic problem with these...
  • Anonymous Mar 14, 2014
    Photo paper does not feed fron the cassett. Says paper jam butpaper is not jammed. Regular paper feeds
  • Anonymous Mar 21, 2014
    paper jams as it goes onto the white portion of copy bed after passing clear plastic.
I also had the same problem and it was a Cheerio that was wedged in the rollers (darn kids). I had to use both the heavy stock to dislodge the cereal and turn it over to dump it out. The heavy stock butted against the sensors, so to get past the sensors, I had to carefully pull up and guide the heavy stock up and over with a paper clip. Works great.
Posted on Oct 15, 2008
I had the exact same problem and it was a foreign object (*** end lol). I fiddled about abit then turned the printer upside down, gae it a few taps and it was fine.
Posted on Aug 21, 2008
You may have a foreign object blocking the path. Move the slide switch to envelope.
Use a piece of heavy stock (backing of a writing pad) put through backwards in the path of the paper output. Be careful of sensors(little black tabs) for the ink head, on either side. If you break them you will have bigger problems.
Lift the scanner assembly while tilting on its back and push the stock to free the foreign object out til you can grab it. Do all this with the printer unplugged.
Good luck - It worked for me.
JM
Posted on Oct 13, 2007
2 Suggested Answers
Arius
  • 446 Answers
SOURCE: Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Posted on Jul 25, 2008
Printer won't feed paper
The unit does not power on.
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
General
errors
Oct 09, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Jul 25, 2008 | Office Equipment & Supplies
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Canon i9950 feed issues
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Paper feed problem
Sound like something foreign is in paper path
Dec 24, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
468 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
