Question about Dometic RM2652 Refrigerator
Dometic rm2652 Have this fridge in my travel trailer and it gets way too cold about 10 degrees farenheit. I moved the thermistor to the center like suggested in some other posts.
    Scholar:
  • 152 Answers
The thermistor is faulty and needs to be replaced or it is too close to the cooling plate , try relocating it if you can and if it continues , replace the sensor. Hope this helps
Posted on May 11, 2009
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Dometic rm2652 heating element is hot but no cold in refridgerator or freezer
disconnect thermistor from back board let run overnite if cold replace thermistor if not replace cooling unit or fridge
Apr 20, 2014 | Dometic Refrigerators
Howw do you adjust temp on a Dometic Americana Model 2652
Should be a thermistor probe inside fridge at back, attached to fins. Fins usually frost up from right to left. Note your thermistor location in regards to frosted end, for example: if your thermistor is placed 5 fins from right, move it one closer to frost if too cold, or 1 more away if too warm. Give 24 hrs. to see how it responds. Move further or closer until desired temp is reached. If fridge does not respond at all, you may need a new thermistor. If you have an ohm meter, you can disconnect thermistor at back of fridge at board and test it. Disconnect 2 wire (P2) plug on board (usually at right upper corner) just below 6 wire plug. Now place thermistor probe in a glass of ice-water, at approx. 33-35F for about 3 minutes and check reading at contacts in plug and you should get a reading approx. 7000-10,000 ohms.
Jun 01, 2011 | Dometic RM2652 Refrigerator
Dometic rm2652 fridge section freezes everything
Hello Keith,
Just came across your question, hope its not too late to answer.
Your freezing problem for the fridge section is likely caused by
1) the thermistor has worked itself loose from the cooling fins.
2) the thermistor is no longer on third fin from the right
3) the thermistor is failing.
Jun 26, 2010 | Dometic RM2652 Refrigerator
Have dometic three way fridge in pop up truck camper that is cooling but not cold enough stays at about 50 degrees answers???
Find thermistor/thermostat that is usually attached by plastic holder at back on one of the fins in fridge compartment. Pull it off, and move it over to left 2 fins, then give 24-48 hrs and see if any change.
Jun 16, 2010 | Dometic RM2652 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
545 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
