Question about JBL BP1200.1 Car Audio Amplifier
Hi there just picked up a jbl bp 1200 for good price although just wired it up and turned the key to find the red light come on few seconds then solid green and no sound...checked ground,remote wire rca connections..even put grounbd right to battery????need help hope i didnt get f#$%ed...
  • 2 more comments
  • kevin_black_ Apr 15, 2009
    hi there dynami ya u got it i didnt get the manual..i got a pioneer lcd screen face with 1 gauge wiring i dont see any dipsiwtches or anything on the amp it is a jbl bp1200 and aswell got nice rca wires aswell and i checked the wirirng sevral times...is testing the ground by putting it directly to the battery ok? i did so and no help
    hi there dynami thanks for the info and manual read it over think i understand it tried it last night and didnt work was frustrated though was getting late gona try it again when im done work today thanks again buddy ill get baqck to u with the details of success or failure..lol
    and oh ya there are two alpine type r 12" and i also had 2 mtx that are a supposid 300 w rms that i was gonna hook up and see how it goes...lol mix and matchin they were lyin around brand new in the box...they shoukld be good no?
    also i bought 1 gauge wiring and the manual sais it can handle up to 4 guage is that a problem
  • kevin_black_ Apr 27, 2009
    thanks...but i went to my buddys shop undid the wiring from amp used distrubution block and all ook thanks or the help ....wierd but true after i tried doing the same several times...but yes a monter of an amp
    Scholar:
  • 45 Answers
Most amps do a "power up" where all the lights can come on, then settle into "green light" or some sort of "ready status" light comes on. The red or yellow lights can indicate "protection mode" (a bad amp) and green is the universal signal for okay. - So try this - Double check your connections and the amp. Pay close attention to the settings on the amp before you declare it not working. I have had many amps (especially newer ones) cause problems from a simple switch that was in the wrong position. Be sure to use good power and audio cables matched to your amps capabilities with good strong grounds on a clean non-painted metal surface. If all is in order from there start checking your signal from the deck to the amp. You can also check manufactures website for the manual, (if you didn't get one) looking at it may give a clue about proper switch configurations and hook-ups. Let me know if you need additional info concerning these idea's.
-Dynami
Posted on Apr 15, 2009
  • 1 more comment
  • ???? ???? Apr 15, 2009
    Alright, I did some research and, found an owners manual PDF for that amp, you can check it out at http://manuals.harman.com/JBL/CAR/Owner%....
    Its seems you picked a nice amp that also has some unique features so make sure to read the owners manual thoroughly. I'v left some highlights here for you to look at and hopefully get you in the right direction.
    Notice here -
    (no audio)
    (Green power LED is lit) make sure speaker-system impedance is within limit (see Specifications)."
    - the reference to speaker impedance. This is very important so get a voltmeter and double check your subwoofer(s). From what I can tell, it seems that your amp will not function unless it sees the correct impedance load from your subs. It will however show a "green light" indicating it is ready for use.
    The correct load should be
    "The total impedance of the speaker
    system connected to a BP Series
    amplifier must be at least 1 ohm."
    I looked through the manual and found another instance that may cause problems-
    When using the speaker-level
    inputs, it is not necessary to connect a
    wire between the “remote” terminal of
    the amplifier and the “remote” lead from
    the source unit. The speaker-level inputs
    will sense voltage on the speaker
    outputs and turn the amplifier on
    automatically.
    Be sure to look over this part in great detail as well, some setups actually won't power the amp unless it sees an audio signal. I strongly believe you have a working amp and you just need to address these issues before getting on your way. Not to mention the amp a is very nice one, and I found several great recommendations written on this amp while doing research for your answer.
    Good luck and enjoy your new powerhouse of an amp!
    -Dynami
    Just give me a few hours or maybe first thing tomorrow morning and I'll have a complete article written up on whats going on with your stuff. I still believe your amp works so I will have further info and idea's for you to try so stay tuned!!!!!
    -Dynami
  • ???? ???? Apr 17, 2009
    Alrighty then lets start with the subs and work our way to the head unit. So...... how many subs rated at how many ohms do you have? According to your manual your amp needs to see at least 1ohm(s) to work. You're going to have to get a voltmeter and check the resistance at the subs in order to determine how to wire them together. If all four subs are rated at 4 ohms you could wire each of them in parallel and they would equal 1ohm. But since they are different from each other you'll need to pay close attention to the lower power subs to make sure they don't blow up. Keep in mind your amp may not work unless it sees a 1ohm load. - So either way I would hook them all up to determine if the amp works. If your subs ratings are different from 4 ohms each you'll have to do the math to figure out how to wire them. If you don't know how to do this, I can, but I'll still need you to get the ohm rating of each sub to me and then I will tell you how to wire them to get your amp to work.
    As far as your 1gauge wire, it will not hook up directly to your amp. Not a big deal but you'll need to go out and get a distribution block and use it to wire your amp(s).
    Also check your Head unit to make sure the sub woofer is turned on. The Pioneer head unit has two different menu's to control that feature, one is the normal sub control menu, and the other requires the head unit be turned off. Example- Turn the vehicle on, and when the head unit is on, turn it off by holding down the source button (sometimes it has an off button), and leave the vehicle on. You can now access the second sub woofer menu in the initial settings menu. For some reason Pioneer makes certain features only accessible from the “off” menu's!?
    So at this point you have checked the subs wiring and corrected it, made sure the RCA's are connected correctly, the head unit is working and the sub woofer output is turned on. If you still have nothing at this point I would try using another amp in its place, this is a good indicator of where the fault lies but does not mean your amp is broken! It might be, but I in your case it might not be. Remember that your amp is not normal - its on/off control is a little weird. From what I can tell it is a very good idea and I'm sure there warranty department isn't very busy because of it. It may decide not to work because off an input issue, heat, impedance, shorts, power, and probably a few I'm forgetting (its almost 3am). So anyway I gave you every option I can think of except having myself look at it. If you are near by I'm sure you can find me and either way your local car audio guys might be able to figure it out if you let them.
  • 30 Answers
Check fuses if not u blow it
Posted on Jul 15, 2009
My 2005 1200 sportster doesn't start, the red key blinking and lights from alarm go on and not signal for start
Hi Mauricio, you may need an alarm reset, for more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Sep 26, 2015 | 2005 Harley Davidson XL 1200 C Sportster...
Neutral light and headlight do not come on when key is turned on harley 1200 sportster 2001
Hi Anonymous, check your bulbs and the headlight ground wire conection at both ends and check continuity on the ignition switch. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Jan 25, 2014 | 2001 Harley Davidson XL 1200 C Sportster...
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
Car amplifier stopped working.
what gauge wire are you using
Apr 24, 2012 | Car Audio & Video
Picked up and used JBL GTS 300 and wanted to install it in my truck. I'm looking for a simple wiring diagram. I'm pretty good at hooking things up but it would be nice to have a guide. JBL is a...
You want to pick up a wiring harness for your truck at your local parts store or online, should be petty cheap. Then all you have to do is match up colors, ie purple with white stripe to purple with white stripe. The other thing you can do is hook a9 volt battery between the similar colored wire pairs from your trucks wiring. Then you will know which pairs go to which speaker. The other ones you need to know about are red, black and yellow, they should correspond directly to your trucks wires, red and black are power and yellow is the accessory
Jun 08, 2011 | JBL Car Audio & Video
My jbl stereo wont turn on. when i turn my truck on it just lights up and then goes straight back off
Hi there Willieulin.
I wonder if the speakerwires are shorting the amp in the JBL stereo!
One or more speakers could be blown......
The protection circuit is most likely doing its job, protecting your stereosystem from damage.
If you have a extra amp connected to the stereo, check if it is wired right.
Try to turn the ignition key "only" so the lights on the stereo turn on. If you turn it further so you start the engine it most likely turns the stereo off.
If that happens the powerwires to the stereo are wrongly connected.
Luck with the problem.
Iceman.
Nov 04, 2009 | JBL SF25 Main / Stereo Speaker
Ignition wont turn off
Hi and welcome to FixYa,
Offhand, it would appear that some of the contacts of the main (ignition) switch has fused together. To check, with the ignition switch off and key removed, all wires from the ignition switch must have no 12 volts reading except for the red.
Good luck and thank you for asking FixYa.
Jun 28, 2009 | 1999 Yamaha YZF-R6
JBL BP1200.1 Car Audio Amplifier Logo
496 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
