Question about Mtd Garden
My mtd rider wont crank,the battery is charged and,has a new igniton switch.whats going on?
  • 1 more comment
  • lknorton Apr 15, 2009
    the starter wont engage but i can jump the starter and it will turn the engine over.
  • lknorton Apr 16, 2009
    just to let ya know,the fuse was blown.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    the starter is not engageing or just click click
SOURCE: Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: mtd riding mower model 13AT688H731 B&S 21HP
Did you change the voltage regulator???
Posted on Apr 24, 2009
SOURCE: mtd 10.5Hp will not crank 36 inch cut
blown fuse by solenoid
Posted on Jun 06, 2009
  • 623 Answers
SOURCE: I have a MTD rider, iam looking for a cheaper deck...
Try your local NAPA store. Bring the old belt with you.
Posted on May 24, 2010
  • 13 Answers
SOURCE: john deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
Posted on Jun 10, 2010
Which fuse controlsstarter when igniton is turned on wont crank must hot wire new starter new battery
Need to know what make car and year.! Most cars have a relay and there Is a park neutral switch ,car has to be in park or neutral .Sometimes these switch go bad an won't let the car start. Then there is the Anti-theft system ,If the light is lit on the dash some makes will not let the vehicle start.
Jan 06, 2015 | Cars & Trucks
Why rider mower wont shut off?
The ignition switch may be broken or have a loose wire.
May 28, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
TRIED TO START 2002 DYNA LOW RIDER. turned key on,run switch to run and hit satr it turned over and fired once then nothing ,did not click or turn over when hitting start. waited a while and tried again...
Make sure battery has a full charge and both positive and negitave battery connections are clean and tight.Make sure unit is in nuteral and try to crank. If engine wont crank check starter selonid or relay. MAKE SURE BATTERY HAS A FULL CHARGE.
Mar 16, 2014 | 2002 Harley Davidson FXDL Dyna Low Rider
Car wont start have p16 10 code and red ligth key stay on
The most common cause of a non-starting car is the battery. It is either weak, (low voltage) dead, (zero voltage) or has bad connections. (corroded or loose) I will assume you have a fully charged battery with good connections. (both to battery and starter relay)
If you remove the starter switch lead (small wire) from the starter relay and apply +12v from the battery to its respective prong or lead on the relay, and your starter cranks, your starter switch is faulty. (not to be confused with your key switch). If you jump the two large wires together on the relay and it cranks, then the relay is faulty. If you jump the two large wires together and nothing happens, then starter is faulty, or wires to starter are loose or broken. Picture of starter switch prong on the relay is pictured. NOTE: sparks are to be expected, so don't be too scared.
fuel system is faulty. Check for a clogged fuel filter, or if your fuel pump don't run at all, replace the "fuel pump relay". Sometimes your fuel pump will run, but be too weak to hold pressure, which will let your car idle somewhat, but be too weak to run the engine at speed or under load.
If your car is getting fuel, then the igniton system is faulty. Things to check or replace in the order that I would check them are here: They are the coil, igniton module, cam and crankshaft sensors, map sensor. Your car may be out of time due to a broken timing belt/chain, or it may have been loose and jumped a few teeth on their cogs. Check engine timing and condition of belt. These are not all of the igniton components, but the most common items that go bad. The rest of the components and sensors shouldn't cause your car not to start, but affect driveabiliy.
Dec 16, 2013 | 2007 Nissan Maxima 3.5 Sl Sedan
I HAVE A 2000 LOW RIDER. PUT BATTERY IN AND FULLY CHARGED. WHEN I TURN ENGINE RUN SWITCH TO RUN ENGINE LIGHT DOES NOT COME ON MOMENTARILY AND BIKE WONT CRANK. JOE
Do you have the turn signal security on your bike? If so, have you made sure it is not set and the battery is good in the key fob?
Mar 30, 2011 | Harley Davidson FXDL Dyna Low Rider...
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I HAVE RYOBI (MTD) LAWN TRACTOR THAT HAS TWO
There should be two wires going to the seat switch. Stephen.
Nov 18, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mar 22, 2009 | Mtd Garden
Garden Logo
146 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
