Question about Fisher Refrigerators
I have a Fisher and Paykel Fridge Model E442BRM serial number ESQ723962. I need a new door for the freezer section. The part number is 322528P. The fridge is approx 3 years old, apparently the stainless steel colouring is slightly different now and I want to match our existing fridge.
3 Suggested Answers
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
I have a 10 years E521T fisher & paykel. The freezer compartment is working fine, however the fridge compartment is not working even adjust temperture. It's beeping and can be reset with pressing
From thee sounds of your issue you will need a sensor or a fan motor to move air from one section to another. Most likely this would be a fan motor located within the freezer section either not running or air flow is obstructed and can't leave the freezer section to enter through passages to cool the other section. Locate the air ports within the refer section, open freezer door (is there air coming out of air port in this section?). Now, close door to freezer, (is the same air flow still there?). If not you have an air flow restriction and this would need to be addressed. Good Luck, hit me up if you have more questions
Apr 04, 2014 | Fisher and Paykel Active Smart® E522BR...
South africa
Fisher and Paykel have a 24hour help desk. Source the number, have your model and serial number handy and they will be able to sort you out.
Feb 14, 2014 | Fisher and Paykel Kitchen Ranges
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Refrigerators Logo
64 people viewed this question
Top Fisher Refrigerators Experts
John Tripp
John Tripp
Joseph Hoffmann
Brian Coughlan
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
