Question about Hoover U9145-900 Z Bagless Upright Vacuum
Hoover Z700 the mechanism that closes off the vacuum behind the agitator brush will not open.
You will need to take the top off. It is easy: turn the vacuum over and look at the bottom (where you can see the beater bar). There are some deep screw "wells"; these are the screws you need to take out plus the 4 silver looking screws that hold the beater bar plate in place. When you bet those out, there there will be a "notch" at the front, behind the LED light you will have to disengage. Turn the vacuum back over and take the gray top off. You should be able to see the engagement latch that is attached to the handle. This is what opens and allows the flap to shut. It has a spring attached that may have come loose. Good luck.
Posted on Apr 25, 2009
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
My hoover steam vacs brushes will not turn . could there be a belt broken? I have misplaced the manual
For the manual:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
For the brushes:
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
The gear box that drives the brushes is driven by vacuum air, running the turbine inside.
There are no belts, just direct drive.
Mar 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn
Sep 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brush roll needs replacement
To change the beater bar you would need to open up from the bottom.To get the parts you would need to produce the model and serial numbers to your local hoover dealeror cheak on the internet for your closet dealer and order the part.There not to bad to change hope i helped:)
May 18, 2009 | Hoover U8143-900 Upright Vacuum
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
Sep 13, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Hoover U9145-900 Z Bagless Upright Vacuum Logo
278 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
