Question about HP LaserJet P2015d Printer
I am trying to install an HP Laserjet P2015D printer in Windows Vista. When I run the setup from the installation CD, I get an error that says, "this software cannot be installed using 'run as...' command. It goes on to say to log on as an administrator which I already am. I also tried "run as administrator" - no luck. Then I downloaded the driver from hp.com - tried PCL5, PCL6, and UPD. These all have a program called EZInstall.exe which detects the printer (it instructs you to connect the printer at the outset) but then installation fails. Any help is appreciated.
  • douglasharro Apr 15, 2009
    Hi jrey_tech,
    Thanks. I did download the Vista driver from hp.com (see my original message - "Then I downloaded the driver from hp.com" (it was the Vista driver - I tried PCI6 first)).
    I just tried this again and got the same result. I run the EZInstall.exe application from the download. I click Next to start; then connect my printer and turn it on as instructed; the program displays a message that says, "New printer detected. Please waits..." Then after about 10 minutes, the message changes to "Installation operation failed."
    Do you know what else I can try?
    Thanks again.
    Problem Solver:
  • 5 Answers
Your P2015D model has been around for awhile. Windows Vista is relatively new, therefore the installation CD may not have a driver for Vista. Try downloading a Vista driver from HP.com (free of charge). PCL6 is probably your best choice. Try the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1845555&taskId=135&prodTypeId=18972&prodSeriesId=1845551&submit.y=6&submit.x=9&lang=en&cc=us
Posted on Apr 15, 2009
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
I am trying to install a laserjet P2015d on an XP machine. I do not have the original CD. When I download the driver and try to install I receive a request for the hpc20155.xml file. I cannot find this...
Howdy,
What you need is more than the drivers. Go to HP.com, look under support and downloads, and download the install wizard for your printer and OS. Follow the directions exactly as plug and play will not work well, often.
Apr 18, 2011 | HP LaserJet P2015 Printer
I have a laptop with windows7 so i cant install HP LaserJet P2015 printer ... When I run the setup from the installation CD, I get an error that says, ....
Mmm. Well, once I was unable to install a HP LaserJet P2050 on a laptop. The cause is most probably that it runs Windows Vista, and that the CD isn't compatible with Vista, so I think you're problem is the same. Hope that helps,
Daniel
Jun 18, 2010 | HP LaserJet P2015d Printer
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
Cannot get the printer to install on my computer with Windows Vista - are there updated drivers?
download from this web site
http://www.softwarepatch.com/utilities/hp2300.html
or you can install by using HP laser jet Cd
Oct 03, 2009 | HP LaserJet P2015d Printer
Install Failed - GetDatFilename() Returned False HP Laserjet 3055
You can find & download the need drivers /program here;
http://h10061.www1.hp.com/ccsearch/search?pname=LaserJet+3055&opname=HP+Photosmart+C4180+All-in-One+Printer&qry=driver&submit.x=10&submit.y=9&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=1141647&search=0
Good Luck!
Rich Lilja
Dec 03, 2008 | HP LaserJet 3055 All-In-One Printer
Hp laserhet p2015d driver duplex driver for Pagemaker
Please download and install the Universal Printing Driver - PS version from the followng site:
If the printer is connected via USB, select the Traditional Mode, if DHCP network, select Dynamic Mode.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845555&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-36004-15
Oct 11, 2008 | HP LaserJet P2015dn Printer
Error 1603 Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Dec 13, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet P2015d Printer Logo
702 people viewed this question
Seeker5211
Seeker5211
