Question about Packard Bell iMedia 6826 (P481000502) PC Desktop
Hi Guys I have a packard bell istart 1359, memory max is 2048mb and I currently have 512mb installed. I purchased 2 x 1gb ddr2 pc2-5300 -cl=5 -unbuffered -non ecc ddr2 - 667-1.8v -128 meg from crutial. I have tried to install these in various combinations : one by one in one slot, also together with the original ram but I cannot get the pc to start up I get a beep but no windows and won't startup. I have tried to go on packard bell website to get bios upgrade, but no support from them. don't know if the PC is considered old though only bought in 2007. someone suggested I try clearing the cmos but I'm not sure what to do. can you help? I was also told to try using double sided ram.
  • Terry Vaughan May 11, 2010
    I would call Crutial to make sure that they sent the correct memory modules for your pc. If they say that they did then tell them the problem that you are having to see if they have any ideas.
    Do you have 2 memory slots or 4 memory slots ?
    Usually memory pairs must be matched pairs, so I'm guessing that you will need to use only the 2 new modules and not the old one.
I went to crucial for my memory upgrade the same thing happened you get a beeping noise when uve inserted them the reason for this is because they arent the right mem cards and crucial dont supply the memory cards for the packard bell istart 1359 in the end i got a refund and went to orca instead they work perfect now hope this is helpful :)
Posted on Oct 12, 2009
  • 123 Answers
Some systems require ECC it may be as simple as obtaining ECC Ram......u can try checking the memory that cam with it to see whether it is buffered and ECC if it is you will have to obtain same type of RAM
Posted on Jul 31, 2009
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
How much ram can it hold and where do I get the ram. There are 2 slots. The laptop is fine just very limited and slow because of memory. Lincoln
512MB(min)
2048MB (max)
2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM, dualchannel
support requires two memory modules of same capacity and clockspeed
I usually go to Tigerdirect to get my customers parts.
Here is the site and the type of ram you need.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=10&sel=Detail;30_170_12847_12847,Detail;30_1225_47516_47516
Hope this helps!
Dec 15, 2010 | Toshiba Sattelite A105-S2071 Notebook
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
How much the memory on compaq v3000z can be increased and what type ddr, ddr2 or ddr3? currently it has 256.
Compaq Presario V V3000 Specification Memory Type: DDR2 SODIMM 200pin DDR SODIMM:
DDR, double data rate is a type of SDRAM in which data is sent on both the rising and falling edges of clock cycles in a data burst. It is usually referred to as DDR as opposed to DDR SDRAM.
SODIMM, small outline dual inline memory module. Smaller and thinner than standard DIMMs, SODIMMs are typically used in laptop computers.
Memory Speed: PC2-4200, PC2-5300 Chipset: Intel 945GM Chipset :
A group of chips that together make up a complete computer processing unit, usually on one circuit board (the motherboard). It may include the main central processor, graphics processors, secondary cache memory, and input-output controllers. Memory is one component controlled by the chipset. Standard Memory: 512MB Removable Memory Slot(s): 2 Max. Memory Per System: 2048MB (2GB) Max. Memory Per Slot: 2048MB (2GB) Dual Channel Memory Support: Supported Dual Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using two or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched pairs of modules to ensure the best compatibility for dual channel operation. Tri-Channel Memory Support: Not Support Tri-Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using three or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched three modules to ensure the best compatibility for tri-channel operation. Install Memory in Pairs: Not Required Install in Pairs :
Memory modules must be installed in pairs of matched memory size. This means that if you purchased your computer with 128 MB of memory installed and you want to add another 512 MB of memory, you must remove the two continuity modules and replace them with two 256-MB memory modules.
Aug 19, 2009 | HP Compaq Presario v3000z Notebook
How to replace memory fro 512 to 4gig
Here's are the tips to replace you memory from 512 to 4GIG.
  • Configured with 512MB DDR2 SDRAM (both Memory slots may be occupied)
  • 256MB(min)4096MB(max), 2 memory slots using 256MB, 512MB, 1024BM or 2048MB PC4200 533Mhz or PC5300 667Mhz DDR2 SDRAM, dual-channel support requires two memory modules of same capacity and clockspeed.
Hope this might help you.
Aug 07, 2009 | Toshiba Satellite M105-S3041Notebook
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
Ram For Packard Bell Argo C -
my wife owns one of these computers and it is identicle to my advent 7201 laptop. both have been up-graded to 2 GB with memory purchased from 7dayshop.com (2 x 1GB)ddr2 memory. go to crucial.com and use their memory tool to advise. I do not know if it will take 4 GB? it used to be like wading thru treacle, with 2gb and removing some of the start-up programs it sings, regards HTEETH
Jul 17, 2008 | Computers & Internet
Suitable psu for packard bell istart 1359
Unfortunately, no. See this link for a picture of your supply: http://www.cwc-group.com/fspgrfsposu2.html . It's considerably longer and narrower than a standard ATC power supply. This is typical of Packard Bell, e-Machines and many others.
Hope this helps!
Jan 31, 2008 | Computers & Internet
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
321 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Daniel Florin
Daniel Florin
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
