Question about Philips SA2315 MP3 Player
Frozen all the screen shows is phillips will not power off have to remove batteries to power down but that doesn't restore either also device manager doesn't want to do anything but upgrade Help! Thanks
You may have to re-format the mp3 player if it does not have a reset button. This unfortunately will erase everything on it. A suggestion would be to move all your files to your computer hard drive and then after reformatting move them back. To reformat connect the mp3 player to the hard drive. Click the right button on the mouse and select format then start.
Posted on Sep 30, 2007
SOURCE:
HTC plum z100 hardreset
If the phone is frozen and you just want to "pull the battery" hold the power button for at least 10 seconds and the phone will power off(simulates a battery pull in devices with non removable batteries)
If you would like to do a factory restore(hard reset)
Ensure the device is powered off.
Press and hold the Volume Down button then press and release the Power button.
Note When the screen with the three androids appears, release the Volume down button.
Press the Volume Down button to select Factory Reset then press the Power button.
Note Allow several minutes for the reboot process to complete.
Jul 12, 2014 | HTC Cell Phones
Still frozen
Press and hold [VOL+] & [POWER] until the player resets.
If the player restarts normally then all is well.
If not, reset again and connect the device to the PC.
Install and run the Device Manager software from the product CD.
Select Repair / Restore option and follow the on-screen prompts.
Goodluck..
Feb 29, 2008 | Philips GoGear HDD6330 MP3 Player
Screen goes black
Please disconnect power cord. Remove battery. Hold down power button for a minute and connect power cord. If not working, please go to device manager and update display adapter or scan the computer with antispyware program.
o remove malware/adware/spyware:
Please scan your computer using free version of Superantispyware.
http://www.superantispyware.com/
Please run quick scan.
Jun 03, 2013 | Toshiba Satellite A135-S4427 Notebook
My Phillips MP3 Player hangs
Philips SA30XX MODEL GO GEAR NOT DISCONNECT AND NOT WORKING NOW ONLY SO OK TO DISCONNECT
May 16, 2013 | Philips GOGEAR SA6045 MP3 Player
Lg p500 screen frozen
Hi
Have you tried removing the Cell battery and re-inserting it again?
Then try performing a hard reset of your device.This restores factory/original settings on your phone BUT deletes all user data and third party applications.This process also deletes system errors on your device.
  • Press and hold Power + Home + Down Volume key for five seconds.
  • The device will turn on and perform the reset.
Hope it helps.Thanks!
Ken.
Mar 24, 2012 | LG P500 Cell Phone
Frozen mouse with a touch pad laptop computer
file:///C:/Documents%20and%20Settings/GX-620/Desktop/TouchPad_ALPS_v.7.0.1101.14_Vistax86.zip
reinstall your touchpad drivers, and make sure it is not switched off (if you were using an extra mouse)
May 13, 2009 | Acer Aspire 5315 Notebook
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen screen
The fault could be down to firmware or a faulty hard disk.
First of all, install and run the Philips Device Manager from the product CD.
Connect the player to the power supply and PC.
If the player is recognised by the PC, select the repair/restore option in Philips Device Manager, and follow the on-screen prompts.
This will format the player and re-load the firmware. NOTE: THIS WILL DELETE ALL TRACKS ON THE PLAYER.
If this doesn't help, or the player is not recognise, then the following might work:
Download the factory software from the following link:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/060421/060421185016_12769.zip&ofn=HDD6330-17-v1.3.zip
Unzip the file to a new folder on your desktop, and open the folder to show the installation files and folders.
Connect the HDD6330 to the power supply and the PC. Before the HDD6330 registers on the PC, press and hold [VOL+] & [POWER ON] to reset the player.
As soon as the player resets, press and hold [VOL-], until PC recognises the player as a removable drive.
Player will show the connection icon on screen but without the bar and battery indicator at the top of the screen. You may need to try this several times to get it right.
When the player shows as "GOGEAR" or "MDJUKEBOX", right click on the drive from My Computer and click format. Click on "Quick Format" and complete the process.
If the player does not allow you to access or format the hard disk, then the disk is probably faulty.
Copy ALL of the files from the new folder exactly as they are (not including "New Folder", into the HDD6330.
When the copy process has completed, safely remove the HDD6330 from the PC, but leave connected to the power.
The player will restart and eventually show "Burn Success"
Press and hold [VOL+] & [POWER ON] to reset the player. The player will restart as normal, and hopefully go into the main menu.
If this still doesn't work, but the process worked ok and the player still froze on "Loading" then the PCB is probably the cause.
You can obtain a replcement from www.cheapestelectrical.co.uk
They are not listed on the site, but they definitely have them available. Unfortunately, they don't have the PCBs for the HDD6330.
Go to the about us page and contact them by phone or e-mail.
May 10, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips SA2315 MP3 Player Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
