Question about Fujitsu LifeBook C2340 Notebook
Primary master hard disk locked. i dont know the password.
4 Suggested Answers
kikoksky
  • 119 Answers
SOURCE: need to bypass primary master HDD user password
the only solution is for you to call the acer tech support and they can generate a password for you to gain access to your hard drive and bios.
visit: http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Posted on Jun 13, 2008
lenny297
  • 133 Answers
I would recommend that u take it to a technician but if u can be able to open it u need to remove the cmos jumber inorder to clear the cmos settings, also try to remove the system battery switch on the notebook and the switch it off after a few seconds, replace the battery and switch it on again. It should laod up with default settings which might make other devices not to work since the settings where cleared, so u need to reconfigure the Bio's settings again
Posted on Feb 22, 2008
cygers
  • 516 Answers
SOURCE: my n6410 hard drive is
In order to unlock your hard disk drive. You have to open your laptop and look for the cmos battery, cmos battery is a small circle dry cell and its number is CR2032. The cmos battery are responsible for holding the bios settings like the system date and time. The purpose of removing the battery is to clear the settings you save in your bios/cmos settings, just remove from its base and put i back after 10 seconds. With this procedure it will unlock your hard disk drive and now you access your computer. The problem here right now is the opening of your computer. You have to be careful while opening your computer you might break the casing or damage some parts. Have a nice day.
Posted on Feb 05, 2011
Aspire one laptop I turn acer on and screen shows Harddisk Primary Master ST9160310AS lock
All solutions point to having to contact the drive manufacturer or laptop manufacturer. There is good explanation in the Tom's Hardware thread at the end, about a 'master password' ...
4.June.2014
Hard disk security primary master lock
harddisk security primary master lock
Jun 04, 2015 | Acer Aspire One D150-1587 Netbook
Why Is my acer 3050 asking for a primary master hdd user password?
If you dont know your password, you may need to replace the hard drive
Aug 15, 2014 | Acer Computers & Internet
Asus eee hard disk locked and it asks for master password, I don't know it, how can I get around it? Or what is it?
You have too choices, reformat the hard drive," warning " all personal data and password will be erased, or you can go to www.ebay.com type HDD password and go through the list of sellers.
Jul 19, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
PRIMARY MASTER TOSHIBA MK1652GSX LOCK
If your hard drive is locked you're out of luck. I'm not calling you a thief, but 99% of the time when you encounter a computer that has a password on the hard drive and the person in possession of the computer does not know the password, the computer is stolen. Hard Drive passwords are put on to keep thieves from getting to sensitive data.
May 25, 2012 | Toshiba Satellite A135-S2276 Notebook
How do I change the Primary Master HDD Master Password?
You've got a real problem. I'm not calling you a thief, but 99% of the time when there is a computer that has a lock on the Hard Drive and the person in possession of the computer don't know the password, the computer is stolen. The Hard Drive Password is put on to keep thieves from getting to sensitive data. It could be set by the real owner remotely once they realized the system was missing.
May 24, 2012 | Computers & Internet
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
HARDDISK SECURITY PASSWORD FOR WDC WD3200BPVT-22ZES
Saw on a forum that this could be the default password.. wdcwdcwdcwdcwdcwdcwdcwdcwdcwdcwd
-put DOS on a floppy disk
-add atapwd.exe to the disk
-turn off the computer & connect your Western Digital hard drive.
-turn on the computer and inset floppy
-type atapwd.exe after A:\
-when the menu loads click on your harddrive
- >Prepare Erase
- >Erase
-enter the password " wdcwdcwdcwdcwdcwdcwdcwdcwdcwdcwd "
-It should come back with an error, press enter and the hard drive name will disappear from the list
-DO NOT RESTART-...Your harddrive is being formatted.
-Let it sit at that screen for 30mins
-Afterwards, press the F5 key(refresh) and the hard drive should reappear on the list
-restart...and it'll be unlocked.
I don't know if that will help your problem but I hope it helps someone. :thumbsup:
THIS WILL DESTROY DATA ON THE HARD DRIVE
Jun 24, 2011 | Acer Aspire 5315 Notebook
My acer is only showing a big ble hard disk security primary master locked, I forgot my password and now have to acess some files but can't cuse I am locked out of my computer can you helpme.
If the password was for windows, not bios password, then
you can use Hiren's boot CD, it have tools to unlock the password,
also, it have Mini Xp, that can be lunched, and then you can access your files
Please tell us your results
Good Luck
May 13, 2011 | Acer Aspire One PC Notebook
Hard-disk #44w4z2y3764-595B the system primary HDD, is protected by password authentication system how to solve this problem how unlock it by correct password?
Here is your Dell Hard Disk Master Password for HDD serial #44W4Z3Y3764-595B
Your HDD Master Password is: w2cuzked
When asked for HDD Password use the HDD Master Password to unlock the HDD password. The Dell HDD Master Password is what Dell can calculate for you or a third party.
Thanks to the great guys at unlockbiosrecovery.com for providing the HDD Master Password that will unlock your hard disk. They can unlock your laptop bios or hard disk.
Apr 01, 2011 | Dell Inspiron 8200 Notebook
Need to bypass primary master HDD user password
send me ur email and I'll give you link for software to remove all passwords in bios or windows
Jan 26, 2009 | Dell Inspiron 2650 Notebook
Computers & Internet Logo
829 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
