Recorded DVD will not play in another player
I recoded a movie on a Samsung DVD R-155 using a DVD -RW disc. It will play on the recording unit but not on another player. The disc was in DVD - VR format. When placed into another player is shows as incompatable disc. A friend recorded a DVD - RW with the format of DVD - VR on his recorded and it plays in all my players. How can I fix this problem? thanks Wolfrem
If you record something in VR format, then it wont play in your dvd machine despite what kind of dvd you use. You need to record in "video format" if your camera supports it. Problem with that then is you cant edit or delete scenes. Also you must finalise your dvd before sticking it in your dvd machine in order for it to play. You can unfinalise it later if you want to add more stuff to the dvd.
I bought a samsung dvx100. I am using dvd-RW disc and am restricted to recording in video mode only. If I record in VR MODE it wont play on dvd machine :( so i cant edit or delete now either.
p.s dont forget to finalise the disc.
Posted on Apr 25, 2009
    Sergeant:
  • 187 Answers
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Posted on Apr 15, 2009
2 Suggested Answers
  • 259 Answers
SOURCE: recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Posted on Mar 26, 2009
Can DVD'S be fixed to play on any dvd player?
,THATS GOOD NEWS. cheers,,. u don't mention what recorder u r using when u put the tdk-R IN,,, DOES IT TELL U TO format the disc ???????? if it does and u don't format it will not record on disc Hi again if u wa?t to use RW rewritable disc's then u don't have to finalize them to play on other DVD players u can buy rw disc's on ON. E/EBAY Cheers.,..,..,...., try another brand of disc like TDK .THEY R GOOD ..when u have recorded a movie go into youre menu and find FINALIZE ..when u have finalized the disc it will play on most dvd players good luck
Oct 19, 2015 | Televison & Video
Samsung dvd_vr330 wont play pre recorded discs
The VR330 has several problems similar to this, and some can be "fixed" by unplugging the unit and let it set for anywhere form 5 mins to several days.
I think the control software gets messed up.
I had 3 - one wouldn't play a "video" movie, another would record RAM, and another wouldn't do DVD-R/RW.
Surprisingly one day I accidentally put a DVD-RAM with recordings on it and the unit accepted the RAM. The disk had been protected on another device.
On that particular unit I had neglected to set the time which was at factory 2006, so I left it there.
Mar 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Disk formatting fails every disk. I used new dvd+rw..
What do u mean by formatting?U can't formatted the DVD+RW disc to blank again,after the disc been recorded and used.DVD+RW recodering mean something are recorded u can recorded some elese in it replaced what was there,that all u can do to it.U can't wipe out what in the disc data was there.
Aug 04, 2011 | Cyberhome DVR 1600 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Which disc can be used to recrord on ?
According to the user manual, the following DVD media you can record with this unit are:
RECORDING: TYPES OF DISCS YOU CAN USE FOR RECORDING
DVD+R 2.4x, 4x, or 8x ONLY; DVD+RW 2.4x and 4x ONLY.
NOTES:
It is NOT possible to record on CD-R or CD-RW discs.
IMPORTANT: It is NOT possible to record content that is copy-protected. This is usually true for most pre-recorded DVD discs and most pre-recorded VHS tapes.
PLAYBACK: TYPES OF DISCS YOU CAN PLAY
DVD discs - DVD movie discs (DVD-ROM); DVD+R; DVD+RW; DVD-RW (must be recorded using video mode or VM); DVD-R (must be recorded using video mode or VM and must be finalized).
CDs (Audio CDs, CD-R, CD-RW) - Audio CDs contain musical or sound content only. mp3 discs are CDs (CD-R or CD-RW)
that contain mp3 files. This product also plays CDs that contain JPEG files and Multisession CDs.
Video CD (VCD) and Super Video CD (S-VCD) discs - Like DVD video discs, VCDs contain picture and sound content. The difference is the amount of information that can be stored on the disc.
VCDs typically have lower picture and sound quality than DVD discs.
Super Video CDs (S-VCDs) can be used to record up to 70 minutes of digital sound and video, with MPEG-2 standard video and MPEG-1 standard audio-but you must use DVD+R or DVD+RW discs to record on your DVD/VCR not S-VCDs.
Additionally, S-VCD disc compatibility is dependent on which MPEG coding software, disc design software, and disc writer software are used; and the discs themselves.
(The above information is extracted from the user manual for this particular model and is a guide only)
I find it very strange that the user manual does not provide any information about DVD-R recording since this is a DVD recorder. I guess you could try those types of discs in it, otherwise it will playback finalised DVD-R discs recorded/burned in another machine.
I assume you have the original manual for this unit. If not, you may be able to download it free from various sites. (retrevo may have it but they may ask you for email address prior to downloading)
I hope the above information helps a tiny bit with regard to DVD formats for this unit.
Mar 12, 2011 | RCA DRC8295N DVD Recorder/VCR
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
Recorded movie on dvd-rw will not play on another player
Mar 26, 2009 | Televison & Video
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Jul 10, 2007 | Samsung DVD-R155
Televison & Video Logo
507 people viewed this question
Top Televison & Video Experts
Electro Med Services...
