HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
TV SONY MODEL KV-29FV300, CHASIS BA5D HORIZONTAL OUTPUT TRANSISTOR D2645, SHORTS WHEN YOU POWER ON TV: CERO OHMS BETWEEN ANY TERMINAL BASE COLLECTOR AND EMITTER FLYBACK OK, NO ELEMENTS SHORTED, FLYBACK +B = 135V, POWER SUPPLY OK. AUDIO AND CHANNELS SELECTION WORKS WITHOUT HORIZONTAL TANSISTOR CONNECTED AND THEN :: LED FLASHES FOUR TIMES i DONOT HAVE DIAGRAMS THANKS AND REGARDS
    New Friend:
Hi in tv monetor crt use vertical yoke conaction ok when horezantal yoke conact then tv short pozetion 110volt 42 volt help please
Posted on Sep 11, 2013
My china tv kit in use monetor crt when conact deflaction then powersupply is 75 volt sereas bulb teak load
Posted on Oct 28, 2012
    Novelist:
  • 159 Answers
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Posted on Apr 15, 2009
  • Akhtar Sep 11, 2013
    hi in tv monetor crt use vertical yoke conaction ok when horezantal yoke conact then tv short pozetion 110volt 42 volt help please
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a Sony Trinitron 34" tv. It will not turn on. The red light blinks 6 times then pauses and blinks 6 times again. Is this an easy fix or time to get a new t.v.?
hi,
ur tv has problem with horizontal output stage. check the horizontal output transistor. if it found short replace the same and switch on the tv. if the same fault occur again, then the lot (line output transformer) may be faulty. also check for any dry soldering in the power supply stage and horizontal output sage.
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV-DZ29M61 horizontal deflection problem
You cannot use sub parts on sony use sony parts only. Same with hori output transistors. USE SONY PARTS ONLY.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV - worth fixing or pitch?
Horizontal output and regulator transistor often short out on this model causing a dead condition. Also the resistor right next to the regulators goes open as well. Electronix.com has a sony repair kit to fix the power supply. You just have to check the numbers on your Horizontal output transistor to make sure you get the right kit for your model.
Feb 03, 2008 | Televison & Video
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
KV-32XBR15
Yes, you should check other parts. The horizontal output transistor is more than likely shorted. Also the flyback could have gone bad. Some SONYs have problems with the horizontal driver transformer which is connected to the base circuit of the horizontal output transistor. If this little transformer has a loose solder connection, it will take out the horizontal output transistor. This may give you some insight as to where to look for your problem. Stargazer
Jun 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
381 people viewed this question
Top Televison & Video Experts
