Question about Refrigerators
Ice maker not making ice. I relpaced ice maker and still nothing
  • 1 more comment
  • fern dogg Apr 15, 2009
    kenmore 106 57026601 side by side
    yes, i stuck piece of wire about 5 inches deep
    ice maker not making ice. I relpaced ice maker and still nothing
    Scholar:
  • 109 Answers
I am assuming this is not a newly installed fridge and that you replaced the icemaker unit because it stopped working... If this IS a new install I must ask the maybe not so obvious question... is there a water line connected to the water port on the back of it? The following are comments straight out of the manual:
Is the supply shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
If all of these conditions have been met and you still get no ice after 24 hrs, we will need to perform some basic electrical tests (is it getting power?)
Hope this info is helpful... ;-)
Posted on Apr 15, 2009
    Brigadier General:
  • 5,158 Answers
What brand and model number is your refridgerator ?
  • Roberta Smith
    Roberta Smith Apr 15, 2009
    have you checked the tube that supplies water to the ice maker to make sure it is not blocked ?
My Whynter UIM-155 ice maker used to make alot of ice quickly. Now, it does not make very much ice and it takes a long time? What should I do?
look at the condenser coli to see if it is dirty if so clean it. Dirty coil will cause it longer to make ice. also make sure nothing is blocking the condenser return.
Aug 20, 2013 | Whynter UIM-155 Stainless Steel Built-In...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | KitchenAid KTLA19EMSS Stainless Steel Top...
Ice maker quits working
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
poptypty
May 23, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker will not make ice
If the ice maker has ice in it then the ice maker is bad but if the icemaker is empty do this simple test, add some water to the ice mold and wait a couple hours, if it makes a batch you probably have a bad water valve and if it don't then the ice maker is defective. Nothing else in the ice box determines ice production OR add the water but the ice maker itself, so if the water vale is good the IM is bad. I have more on this with manuals and repair photos: HERE
Jan 23, 2010 | Refrigerators
The module on my 506 is flashing twice, ie, long harvest, how do I fix this problem , ?
if its been awhile since this unit was cleaned..what happens is your bin level sensors start to get dirty or scale build up..but not enough to cause bin full light to come on...clean senors.ice machine..acid wash..rince....if it continues relpace sensors...make sure when ice falls they are good size or enough for sensors to pick up
Nov 11, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Frigidaire PLRS267ZAB Side by Side...
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
