Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
WHIRLPOOL ICEMAKER DESPENCER STOPPED WORKING.
WHIRLPOOL SIDE BY SIDE ICE DESPENCER MOTOR STARTS THEN STOPS.
  • 3 Answers
It is either the motor going bad or the switch at the ice lever. The little micro switch that is activated by the ice lever is likely held in place by two little, week, plastic pins. They break easily. After one pin breaks, the switch can still be close by the lever, but it is hit and miss. It is a ****** to replace the bracket unless you have some experiance. One other long shot would be the freezer door light switch that shuts power off to the dispenser when the door is open.
Posted on May 01, 2009
Door icemaker will not dispense ice. Motor starts
At the very least you have worn out coupler components. Determine what the motor issue is and replace it if necessary also.
Eric
Oct 16, 2009 | Whirlpool GS6NBEXR Side by Side...
In the door ice maker has stopped working. the light controller s
when you look at this icemaker there are 2 sets of strippers 1 stationary the other moves. teh one that moves is normally at 2 o'clock position facing the front cover of icemaker. if these teeth are in anyother position for longer than 10-20 minutes then you most likely have a bad motor module on the icemaker, this is a very easy repair you will need partnumber 8201515 from whirlpool or local appliance supply house. thx peyton
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore koldspot model 106.56532400
Oviously you need water first. You'll have to check that the fill valve is opening and that the water is making it to the icemaker. Make sure the fill tube that feeds the water from the back of the frige to the icemaker is not frozen. Be aware, just because you get water at the dispenser doesn't mean the valve to the icemaker is ok. If you are getting water, you need to check that the icemaker is not jammed, sometimes ice can fall back into the icemaker, or get caught in the ejector. You may need to remove the icemaker and run the mold under hot water to melt the ice. If it was jammed, you'll need to check that the fill level is correct to prevent it from happening again, both too much water and too little water can cause problems. There is a heater that helps loosen the ice from the mold, because of that there is a thermal fuse to prevent it from over heating. It will be molded into the wiring harness supplying power to the icemaker. If you have continuity through the fuse it's ok. If you don't the heater shorted and you will need both a new icemaker and that wiring harness.
Jul 19, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side icemaker won't stop... lol
no you shouldnt have to replace the ice maker, the stop arm probably is not in place. pull the ice maker out and check where the arm goes into the motor head. I think that will solve it for you. Good Luck.
Sep 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
234 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
