Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Why does my washer smell like mildew? I've tried running bleach and vineger through it but it still smells.
Why does my kenmore washer smell like mildew? How do I get rid of it?
  • 116 Answers
Usually from soaking clothes after a while the foam from soap sticks to the plastic drum where the bubbles are. its usaully above water level so doesn't get rinsed very well. manually get in there and wipe it out or try overfilling a tad with hot water and try to break it loose also make sure your lint trap is clean.
Posted on Apr 15, 2009
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
Moldy mildew smell won't go away.
When I get the mildew smell , I run the machine empty and only use bleach. Then when done leave the door open to dry out. Works every time.
Oct 23, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Wet clothes after spin cycle and bad mildew smell. I have seen many complaints about mildew smell with He3 & He4 well really frnt loaders in general. The bad mold is so gross and the smell is horrible.
Clean tub boot the best you can with bleach. Then run an empty load with sunlight automatic dish soap (verry little). Then this should clean and freshin the washer up. The best thing to do is not to shut the door on washer when not in use.
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Weird smell
Probably mildew. They often suggest running a bleach only (no clothes) cycle every month or so with front-loading washers.
Oct 09, 2006 | Kenmore 44102 Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
318 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
