I just installed a used Whirlpool ACQ122XK airconditioner, that has been stored for about a year. Anyways, I turned the unit on before I inserted it into its housing unit and it worked just fine. Then I inserted it into the housing unit and ran it for about 10 minutes and it ran fine, but the front radiator looking piece was sort of grimy, so I turned it off and vacuumed it, even though the bottom of it was sort of wet. I did not bend any of the aluminum pieces or anything, but now it won't turn on. When I turn the unit on, the lights come on and it sounds like it is going to start blowing, but then it clicks, behind the "power square" with the on/off switch and the cool/fan speeds, and the blower turns back off. Then about 30 seconds-1 minute, it clicks again, like if the blower is going to come back on, but then it clicks again and turns off. I have tried to unplug it and let it set for 3-5 minutes and try it again, but it does the same thing over. Do I need a new unit or is this a minor problem that can be fixed? Or even a solution, that I can possibly try, that might make it work? Thank you for any help that I can get!!!
First off, I dont think you caused this problem by vacuuming the unit. It is possible that you did not leave much time before restarts but you then said you tried leaving it off for 5 minutes which should be adequate enough. f you let the unit set for a couple of hours before a restart that should be enough time for the compressor to cool down to ambient temp. I would then try restarting the unit, if it works leave it on for a while and make sure it is producing enough cooling. If there is no change in the situation I would suggest that it would need to come back out of the housing and check that the compressor is receiving voltage to it. It is possible a start capacitor or relay is the cause of the problem. If it started first time I would suggest it is worth having it checked by a professional as it could be the charge or the starting devices. First off though let it completely cool down and try again. Hope this is of some help.
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
How do I change the battery in the remote control for a panasonic inverter air conditioner model no:...
(More)
How do I change the battery in the remote control for a panasonic inverter air conditioner model no: CS-E24GKR
coleman/evcon model drhq0421 hi pressure switch. having a problem locating a replacement. what are...
(More)
COLEMAN/EVCON MODEL DRHQ0421 HI PRESSURE SWITCH. HAVING A PROBLEM LOCATING A REPLACEMENT. WHAT ARE THE PRESSURE RANGES?
