Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
It won't start
It was plugged going into the empty cylinder can you give me a sequence to figure why it has quit. Is their a fuse? BC THANKS bcarmic@earthlink.net
  • mandy7166 Jun 13, 2008
    I tried to turn it on and it stared for a second then quit. It will not come on. It make no noise at all. I am so bummed. I love this vacume.
    any suggestions?
    Amanda
  • fifijules Dec 19, 2008
    Just got my Dyson in my moving shipment from overseas. When I unpacked it from the carton, plugged it in and turned it on, it won't come on. What is the problem?
  • 372 Answers
Hi. Dont fully understand what you mean by (It was plugged going into the empty cylinder) If it is dead check mains lead to switch for any internal break in the lead,This is very common it usually breaks where it enters the machine. If its not the mains lead Check switch unit. I doubt its the motor unless it was giving a burning smell with a popping noise,
Posted on Sep 14, 2007
Power lost on dyson - what do i look for
If the hoover switches on then you may have a blockage in the cleaning head or pipe. If it does not switch on the you may have a break in the cable where it enters the machine. It is quite common for the cable to break there.
Dec 17, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson upright cylinder stuck wont release to empty unit
I have had this happen to me (DC14 Animal). This was my experience:
If you have recently had the motor filter (the "permanent" one under the dust container, right on top of the motor) out and have replaced it, it is important to make sure that the filter cover is down properly, otherwise the canister will not release.
I got the dust container off by pushing it downwards, quite hard before pressing the release button. You really will have to push straight down on it quite hard. Then investigate why the dust container is so high that it will not release.
Jul 30, 2014 | Dyson Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
I was in the middle of using my vacuum when it quite on me. I tried multiple things including letting it cool off for a while as I was using it to vacuum my car outside and it was pretty hot. I also...
Hi the problem you are more than likely having is with the wires that go into the vacume they are not that secure and do work loose.
now if you remove the cylinder that you empty, now you see where the wire goes into the back of the vac, well if you look at the front of the vac in the same place the wires go into the vac you will see a little inspection panel held on with star shaped screws.
you need to undo this to get to the wires
once undone you will see how the wires are secured into the vac you need to undo the connectors screws that secure the wire and remove the mains wire from the vac
now cut about 5 inches off the wire and then peel the outer cable back and cut it back so the two inner wires stick out as much as they used to, then refit the wires in the vac and close it all back up
dont do this with it plugged in as you will give yourself a shock.
when its back together check the fuse in the plug it may need changing due to the short its best if you change it anyway, then switch the vac on and see if it works
give me a shout back if it dont.
please dont mess with it if you are unsure what you are doing as you could cause harm to you and others if you dont put it back together properly
let me know how you get on ok
Aug 14, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson just stopped.
have you changed the fuse in the plug
Jul 11, 2010 | Dyson Vacuums
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I cannot get the top of the dust cylinder to empty it
check for any switches, latches or buttons that me lever, slide, twist or completely remove your cylinder.
These have been designed to be intuitive to use. (I know sometimes these machines appear counterintuitive). Patience and you can find the way.
What model/make of vacuum, and we may be able to find a manual explaining how to empty cylinder.
May 10, 2009 | Vacuums
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
236 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
