Water collecting in the bottom tray and, at time, pouring out
Water is collecting in the bottom tray and pouring out, at times onto the floor.
  • 24 Answers
The condensate drain is probably plugged w/dirt. You have to blow out the drain w/ some pressure to clear the drain.
Posted on Apr 15, 2009
How to get to blow out ac so it don't leak on passenger floor board
The evaporator tray has a hose on bottom to allow the water to drain and leave the car. When that hose gets clogged the water collects in the tray, overfills it and the excess spills out onto the floor. Go under the car, locate that hose and goose it with a nice long metal coat hanger to free up the clog.
Aug 31, 2015 | 1995 Nissan Pickup
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
I have a whirlpool refrigerator model # eb9fvhxvq0 and serial k00801735
in that tray is a hole for drainage. you may have gotten a frozen pea or something in it. take a turkey baster with very hot water and flush through that drain hole till water drains normal. problem solved.
Apr 01, 2012 | Refrigerators
Unit runs all the time and water collects at interior bottom floor.
Is the unit cooling properly? Its a broken or misaligned water hose that runs from freezer to water reservoir for evaporation from compressor heat. Or there is too much humidity causing lots of water to collect inside and your unit is running all time, it can be a case of door not closing properly.
- Please check the door if its closing properly without any gap.
- Any broken pipe inside
- Chiller tray flooded or not in its position.
May 11, 2011 | Refrigerators
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
GE tFX26KR side by side leaks water onto floor
remove the back of the unit at the bottom where the compressor is, it is held in place with 5/16ths screws. locaate the drain tube going to the drain pan, it is held in place with a spring type clamp, remove the drain tube and run water through it till it is clean and not obstructed, reinstall all parts
Apr 11, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
May 10, 2007 | Maytag MSD2754G Side by Side Refrigerator
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
