Question about Hitachi 53FDX20B 53" Rear Projection Television
No picture no sound
My Hitachi projection 53FD(or SD not sure)X20B TV just suddenly wouldn't turn on at all. I've checked every connection, unpluged and re plugged, hit the circut breaker and so fourth. The red standby light is on, and, when I manually touch the power switch, it clicks, but then, nothing. No sound. No picture.
  • DebMax Sep 14, 2007
    could you please give me some more details where to look, what to look for?
    Genius:
  • 1,153 Answers
There are lights on the board about 8 you should look at which comes on and which stay on this by hitachi standards tells you what is wrong. Most of the time its convergence amps bad.
Posted on Sep 14, 2007
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Hitachi 51F520 keeps turning off and on
hi, the tv is not set on sleep timer is it. the other fault could be a dry joint or a swollen capacitor a loose board with the power off you will need to do a visual check make sure you've got a good light hope it helps
regards
shaun
Dec 06, 2011 | Hitachi 51F510 51" Rear Projection...
I have a Hitachi F5F110. The red/pink is way out of balance on this TV. I've done everything I can do to try and fix it, including the magic focus built in on the computer and I've also turned...
51F510 SHOULD use two STK392-150 CONVERGENCE integrated circuits. Too much to explain here but I am available on the site as a pay question attention: SD TECH.
sd tech
Sep 19, 2011 | Hitachi 51F510 51" Rear Projection...
I was just given this Hitachi T.V. and when I plugged it in I have a good picture but no sound. I have tried everything I could by reading the manuel, but no luck.
First, recheck your cables, and their configuration. Make sure whatever source you're using is properly connected to the television. If possible, check your peripheral devices by hooking them up to another TV.
If you're just connected to cable, and if you've already fiddled with all of the on screen menu settings for audio without any luck, then it's possible the TV has some mechanical defect requiring professional repair, and you should not attempt this yourself.
In the meantime, you can try hooking up a stereo to the TV's audio output jacks (use a pair red and white cables to connect the audio out jack on the TV to the auxiliary jack of a stereo). Turn both of them on, set the stereo to aux, and see if you get sound.
Jun 09, 2011 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi model 57SWX20B , Sound, but no picture
I had similar problem with my 57xwx20b TV as well. I'd unplug it from the wall for at leas 30-40s and plug it back in, the picture would return as normal. It will come back from time to time but the same procedure will reset the video board and the picture will return. I'd also check to make sure that the TV has the latest firmware from Hitachi as well. The FW for the ATSC tuner is upgradeable via the SD card and Hitachi website will give you the procedure. This fix all kind of problem with my TV from blank screen, green screen, flashing screen, pinkish screen because the old FW was built before the final standard. Apparently, it interferes with the video board and causes it to go amock. Good luck.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Apr 27, 2009 | Hitachi Televison & Video
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Hitachi clu 615mp
sounds like a loose connection, check splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108 and convergenc ic for loose connections
Jan 08, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
