Question about Whirlpool Washing Machines
UNIT WILL NOT GO INTO THE SPIN CYCLE ON ANY SETTING.
  • 242 Answers
Check the lid switch/door switch.
leave your model for furthur info.
Phil
Posted on Apr 15, 2009
Unit will not drain or spin
pull out the plug
first check the filter
then the pump
Nov 26, 2013 | Frigidaire APWD15GB GLACIAL BLUE PDST...
Water does not turn off during spin cycle
Hi Robert!
If a washer unit is not advancing correctly to the next setting or cycle you could have a few issues. The main control board is not communicating correctly to the rest of the unit; the fill sensor and water valve sensor(s) are not operating properly; or the unit is not sensing enough water has been added to the unit. I would strongly suggest to contact a service professional to test all areas of the unit before repairing any further.
Mar 28, 2013 | Frigidaire FEX831CS Top Load Stacked...
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Will not spin
Hello - Is the drain pump making a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire FEX831CS Top Load Stacked...
Washer does not go into spin cycle
Hello Michael Callegri - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
The machine will fill with water and run through the first part of the cycle, then stop. If I turn the setting dial to the next setting the machine will start, but does not pump out the water. At each step...
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
Nov 16, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
