Question about Medion MD 96340 Laptop
Failure of application &support disc.
when I insert disc I get the following warning.
cannot open swap file.c:\cwsdpmi.swp.
  • 189 Answers
- This warning can actually be ignored, this is not a bid issue and cant harm your computer. Actuall the CD you are using must has the dos based applicatoin which wants to use this swap area and it can't find it. This was some crazy prog developed by somebody to use DPMI applications. My suggestion is as the swap file name is incorrectly specified in the image change the name with cwsparam command.
Posted on Apr 15, 2009
Flash MX 2004 configuration
there are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Mar 24, 2008 | Macromedia Flash MX
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I need to create recovery disks for my HP Pro Book 4310s in case I need to restore it back to factory settings in the future. I just got this computer and was I told I should get this done. I am running...
Hi.
Please follow the steps to create the recovery discs using the HP Recovery Manager.
Click Start>AllPrograms>Recovery Manager.
Select Recovery Manager. This will open Recovery Manager.
Click Advanced Options. If you are using a laptopand operating on battery power alone you must connect to anAC power outlet before you can go to the next step.
Select Recovery disc creation. Click Next. The Recovery Manager will begin creating the necessaryfiles. This may take a while, so be patient until the bar has reached 100%.
Read the table of requirements thatappears. Depending on the type of discs you use, more or less may beneeded; if you use ordinary CDs, Recovery Manager will require more compared tofewer discs if DVDs are used.
Insert your first blank disc, havingmade sure it is fully labeled, such as "Recovery Disc 01" or"Recovery Disc 1 of 2". The optical drive of your computerwill have automatically opened. If not, open manually. Close the optical driveand click Next.
Understand and confirm you want to gothrough with the operation using the type of disc you have inserted by clickingNext.
Wait while Recovery Manager now createsthe first disc. This may take 20-40 minutes as it collects the files,writes the files and verifies the files to disc.
Remove the disc and insert the nextafter the first has been finished after clicking Next. Continue the creation of discs according to thenecessary requirements, up until the last has finished creating files.
Click Next after removing the disc and then Finish to complete the session. Congratulations! You havejust made yourself a set of recovery discs.
Use the recovery discs to recover yourcomputer in case of system instability or failure.
Thanks!!!!!
Dec 29, 2010 | Computers & Internet
I maked a video recording on my Nokia 3120c and the result was too files video0032.3gp and video0032.swp. I can't open this files.is it possible to recover this files view it?
nice day,,yes you can view the files ,,just connect your mobile or multi media card to computer..to view the file.....good luck..
Jul 02, 2010 | Cell Phones
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
CcCommon file
The ccCommon file is indeed related to the Microsoft Installer, which all applications use to install applications in Windows.
try reinstalling windows..its pretty easy
Jun 25, 2009 | Microsoft Office Home and Student 2007...
(french)i have bberry curve 8330 and i receive a eror code 205..
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Medion MD 96340 Laptop Logo
96 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
