Question about Onkyo TX-SR606 Receiver
7.1 speaker setup: no sound coming from right front/surr speakers
Please help...The only time all 7 speakers work is when playing CD's. When watching standard DVD's on a non blue ray machine, sound only comes from 4 out of 7 speakers: front/left speaker, center, surround left speaker, surround rear/left speaker. All right side speakers have no sound during DVD playback. I tried everything including using the microphone setup from the beginning - twice. Even resorted to resetting the setup and still does not work. I tried all the manual adjustments including troubleshooting and did not work. All 7 speakers work fine when I switch it to the pink noise test.
Thanks.
    Problem Solver:
  • 16 Answers
Check the patch cord the right side might have went bad
Posted on Aug 20, 2009
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Posted on Apr 15, 2009
I hope this mail finds you well.i am not getting sound from the surround and center speakers.when i test my speakers i only get sound from the front speakers.
hi,
check ur speaker connection first or may be ur receivers speaker setup have some problem. except frond speaker all the others will be off mode. change the speaker setting.
press osd button on the remote to bring audio setup. select ur speakers large or Small or large according to ur speakers. then test again.
if u connected an analog audio input then press surr (surround mode button) to select the mod you want)
ok
Dec 18, 2010 | Harman Kardon AVR 7000
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Feb 02, 2009 | Denon AVR-1708 Receiver
Music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Mar 05, 2008 | Alpine CDA-9855 CD Player
Curtis dvd5029 home theater system only plays right front and center speaker
Some DVD players in SETUP MENU need to select AUDIO OUTPUT (i.e. STEREO 2 ch - SURR 5.1 - SUB ON/OFF etc.). Check this for start.
Sep 26, 2007 | Audio Players & Recorders
Only 2 of my 5 speakers are working
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Apr 30, 2007 | Philips MX3700D Digital Surround Sound...
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Onkyo TX-SR606 Receiver Logo
665 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
