Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Dishwashwer won't start and can't reset to restart
KitchenAid dishwasher model KUDS230B0. I started the dishwasher and the heating water light turned on but an hour later it was still on and did not start. I hit the reset button and it cycled through and the 'please wait' light came on but would not stop. When I cancelled that, the dry light came on and 3 hours later the light would not go off. Is there a way to reset this or is the dishwasher fried?
  • Anonymous Apr 22, 2009
    Same thing- but haven't tried reset button- didn't know there is one.
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Posted on Apr 23, 2009
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
I have a Kitchen aid dishwasher model # kudpo1ilbs6 the clean light is blinking 7 times then stops for a sec and does it again
I am assuming the problem does not go away when you turn the mains power off and on.
The problem is linked to the temperature variation in the incoming water.
This confuses the diswasher. You have to reset it now. Try this sequence..
Press heated dry, normal heated dry, normal quickly within 5 sec. All lights should light up.
Advance through the cycles by using the start button
Please post a comment to confirm if this helps.
Oct 12, 2010 | KitchenAid Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
No water is coming into the dishwasher. What should I do?
I will have to assume the dishwasher turns on when you press the start button.
Very hard to provide solution without knowing the make and model of the dishwashwer.
Possible causes of water not coming when dishwasher program has commenced are-
1. water tap is not turned on.
2. the water inlet solenoid in dishwasher is faulty
3. the float switch at base of dishwasher (depending on model) is triggered and thinks the dishwasher is already full of water.
Happy to provide a specific solution if i know the details. Please post a comment.
Jun 13, 2010 | Dishwashers
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do you reset the kenmore elite dishwasher? I replaced the faucet in my sink and forgot to turn on the water to the dishwasher....when I started it it went half way through the cycle when I realized...
Turn off the breaker that powers it. If all else fails, take a jug, fill it in the sink and pour it into the bottom of the dishwashwer until it comes to the bottom of the heater, that's the round think suspended above the bottom, below the rack, and turn it back on.
Sep 08, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Old dishwasher doesn't drain
Disconnect the drain line from the sink and put it in a pail.
Turn the timer to a pump out cycle and see what comes out of the drain.
If it still drains poorly, replace the pump impeller.
Mar 11, 2009 | KitchenAid Dishwashers
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Diswasher not working
If you have a Kitchenaid. You need to press in this order.... high temp, energy saver dry, high temp, energy saver dry, the lights will all start blinking, after they are done the cycle will start. Press cancel twice. ;)
Dec 07, 2007 | KitchenAid 23 in. KUDD01DPPA Stainless...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
497 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
