Home | Dell | (E210882) Motherboard | Reinstalled xp with SAT...
Dell Motherboard
Problem for Dell (E210882) Motherboard
Reinstalled xp with SATA drives not booting e210882 motheboard
By sam6905 on Apr 15, 2009
I have western digital sata 320gb drives any help would be great
Clarification Request
Posted by kg4aau on Aug 02, 2009
are you wanting to boot from sata? and do you have sata enabled in bios?
Posted by byteguy on Apr 15, 2009
You say you have "drives"?
Depending on the age of the computer, you may have to install the SATA drivers as you reinstall the O/S. SATA drives are not natively supported on some older motherboards.
Also, in Dell computers, you have to enable the SATA drives in the BIOS settings.
Just what is it that you did and what happened?
Solution #1
posted on Aug 04, 2009
Not Rated)
joeylproctor
Rank: Guide
Rating: 0%, 0 votes
Have you checked your HDD jumper? Make sure it's in the Master position. You can also use the Cable Select setting. For cable select, you need to go to the Bios and make sure that you select your desired HDD as the master drive for boot up sequence.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear... (More)
Answer
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
