Question about Lexmark X4270 All-In-One InkJet Printer
Printer no print
Will not connect to computer try logging off stutting down and still no luck when in printer page and cancel all doucoments and still no luck
    Sergeant:
  • 390 Answers
Odd things printers aren't they? PC communication error caused by a few issues. Try uninstalling it from device manager and reinstalling using original driver disc.
Posted on Feb 14, 2008
6ya staff
SOURCE:
Xerox workcentre 5775 I sent a 1-page document to
All you need to do is uninstall your printer to remove everything and then try re-installing again because otherwise it may be difficult for you to cancel all jobs at once.
Oct 02, 2013 | Canon imageCLASS® MF4150 All-In-One Laser...
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
I have a print job that will not print or cancel. I have cancelled all print jobs throught the controll panel and the status says deleting, however it will not delete. it has said this for three days. When...
hi!!! I always encountered same as your problem, my advise to you is to re-start your pc and your printer because in that kind of problem your pc was hang-up. after you re-start your pc and printer try to print again.
Apr 20, 2009 | Office Equipment & Supplies
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
[email protected]
Mar 20, 2009 | HP LaserJet 4100 Printer
My computer is Windows Vista.Printer ishp officejet4215 all-in-one.I started to print from computer saw article ran 26 pages, so I hit cancel after page 1. Now the printer will not print any new matter...
delete the pending print go to the control panel printer and fax andselect your printer double click there its show pending print deleteall or cancel all and and unplug your printer then connect it restartyour computer then check it.
reply me
[email protected]
Sep 26, 2008 | HP Office Equipment & Supplies
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Cancel printing doesn't work
If you have tried a reboot then why don't you try a Soppler Refresh.
Click on Start> Run (and type Services.msc) Hot ok.
It should open services window up.
Then look for Print spooler> Double click on it> Under General amke sure startup type is selected as Automatic> Then down you shoul see a tab which says stop> Click Stop (Now a small windows popps up and closes) You will see Start Highlighted> Click start and stop will be higlighted> if applicable click on apply or ok and close all the windows and restart the computer.
Then go to Start> Control panel> Printers and faxes> and check to see if the icon say 0Ready> if yes right click on the icon and left lick on Properties and then in the bottom you will see a tab which says print test page> click and see if it prints a test page.
Then try printing any document.
Good Luck
Aug 20, 2008 | HP Officejet 5610 All-In-One InkJet...
How to cancel a printing
Go to Start-> run . Type in services.msc. Find the print spooler service, right mouse click and choose stop. Open Explorer and go to c:\windows\systerm32\spool\printers and delete all files.
Go back to services.msc-- Print spooler. Right click and start service
Apr 06, 2008 | HP Deskjet 3845 InkJet Printer
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
