Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Slow turn over will not start under own power
It is a 17.5 hp briggs craftsman 42" I have a new battery and it is fully charged( good cranking amps not the cheapy ) new gas it will start but only if I jump itand runs fine but hard to get stated. I acctually have to rotate the engine till it reaches top compression to get it to turn over Please help any and all is appreciated Kevin
  • 95 Answers
SOURCE: i have a craftsman lt 1000 w/brigs&straton 17
It sounds like the compression release is not working,it works by opening the exhaust valve during engine cranking.For the compression release to work the valves have to be adjusted,especially after the engine is broken in.Set the engine to top dead center on the compression stroke,the exhaust valve should be set to .004 and the intake to .002. I think you will find the exhaust valve is way too wide which is causing the hard crank problem.Set the valves by adjusting the nuts on the rocker arms,it should be a torx set screw located in the rocker arm.First back the torx screw out about a turn then hand tighten the rocker stud with the feeler gage in place then tighten the torx screw down to lock the setting.
Posted on Aug 06, 2009
  • 17 Answers
SOURCE: Craftsman 14.5 hp 42
Make sure that you have 12vdc at the carb solenoid. If you do, next check your compression. You can do this with a compression gauge or by taking the spark plug out and placing your thumb over the hole and turning over the engine. If you are building compression it will blow your finger off the hole. If not check your valves to make sure they have the right clearance.
Posted on Oct 28, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman 17.5 hp 42 in. Deck Lawn Tractor. Runs
It doesnt sound normal.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
  • 36 Answers
SOURCE: Craftsman lt1100 17.5 ohv engine won't start
try to make sure all connections are clean. i have this same machine that does exactly what you are saying. if battery is all charged up. try setting parking brake.Put in neutral, get off the machine and turn the key. this is what i do and machine cranks fast and starts. my issue is in that saftey switch in my seat.
Posted on Sep 22, 2010
Testimonial: "I had same problem. Kept adjusting the valves thinking that was the problem. Final problem solved by replacing the starter. It had a bad spot on that was caused by previous owner boosting it off with a vehicle. New starter! no more problem!"
daneinwv
  • 124 Answers
SOURCE: I have an 18.5 Briggs
My name is Dane and I'm going to help you with this. I need you to do a couple of steps for me, and one involves using a voltmeter. You can pick up a cheap one at a hardware store or auto parts store. They will even show you how to use it if you need them too. It will come in very handy around the house and well worth the $15.00 you will have to pay for it. Put your battery on a charger while you get the meter so it will be fully charged later. When the battery is charged, remove the charger.
I want you to set the meter up for Volts DC and (With the engine OFF) place the red lead on your battery positive terminal and black lead on the battery negative terminal. If your battery is charged ok, it should be around 12 volts.
Now, I want you to start your tractor, and check the voltage again with the engine running. Do it the same way you did with the engine off. If you are getting around 13.5 - 15V, your mower is charging and you probably have a bad battery. Check your terminals and make sure they're clean and tight. If you got the same voltage with the engine on as you did with the engine off, make sure the electrical connectors coming out from under the shroud of your engine are all connected. I've been doing this for a while now and I've never had a stator go bad yet. Not saying they won't, but it's very rare. To change the stator, which is actually like a car alternator, you have to remove the top cover of your engine and pull the flywheel off. It's normally bolted to the top of the engine block under the flywheel. If you come back and tell me the stator's bad, I'll tell you how to do it. But for now, I think you'll have enough information to get back running again.
Just a note. Those stores which use the resistance type battery testers. The ones that Glow red when they test your battery. They can't really properly test your battery unless your battery is fully charged to begin with. Amazing how much money they make on that little "FREE" test.
Ok, if you have any more problems with this, just add a comment on the bottom of this post. I hope I've helped! Thank you! Dane
Posted on Dec 16, 2010
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman riding mower doesnt turn over easily
I have the same problem and suspect it is caused by a combination of an older starter requiring more amps and the battery not able to supply them. When I fully charge the battery my engine starts OK.
Try leaving the battery on charge for a couple of hours
Mar 11, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. ...
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Jul 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
276 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
