Question about Nintendo DS Console
Will not power up after changing the case
My son dropped his ds and broke the hinge.the ds still worked perfectly so i ordered a case and screw drivers to repair it.after installing the new case i pressed the power button and the green light comes on the lower screen flashes then it turns off.i have taken it back apart three times but do not see anything wrong or out of place. please help that boy is going through nintendo withdrawal. thanks,the car doctor
  • duca212 Mar 21, 2009
    Got the same problem as therad author, and i cant get it to work and its so agrevating!!!!!!!!!!!!!!!
I found this on ebay after a lot of searching forums and other sites, and it worked for me!
"If you are one of the unlucky ones, LIKE me, you may find after taking it apart,and then putting it all back into the new case, that when you power up, bottom screen flashes, and nothing... DONT panic.. I did.. tried looking for help on the web and couldnt find any. It just means you, like me havent pushed one of the Ribbon cables fully in... took me a while to work it out, just unclip the ribbon cable again, and with both fingers gently push it all the way in, you will feel it slide into the socket more than it did before. "
Good luck Duca
Posted on Mar 22, 2009
    Genius:
  • 1,153 Answers
He may have broken part of the board, so look for some tiny fracture or trace broken. I would say look in power supply but it's all so small and all bunched together. Could the battery be dead and not charging? check around the power plug inside unit.
Posted on Sep 14, 2007
SOURCE:
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
Ds shows only half of top screen
a wire has come loose that attatches across the hinge take it to a reputable repairer it shouldnt cost much..............................
Oct 25, 2009 | Nintendo DS Console
My sons DSi was dropped and the left hinge broke. i have been able to repair the hinge (as in put it back in but cover still cracked) and it opens and closes ok but when you switch it on the Nintendo white...
I had this same problem after my son dropped and broke his DS lite. The hinge broke and it was constantly freezing up. I did some research and decided that repair wold be the better and cheaper option to buying a new one. I found this repair place site online www.videogame911.com . I filled out the online order form and shipped it off. They had great customer communication through their website and kept me updated every step of the way.We had our system back within a few days as good as new which made my son very happy and at a very reasonable price which made me very happy. If you are looking into repair for your game system I strongly recommend them.
Oct 02, 2009 | Nintendo DSi Black Console
When powering on it just flickers has been dropped 2 times
There is a short somewhere within the DS. At this point, your going to have to get a new one or send it in for repair. here is the direct repair and troubleshooting line for nintendo 800-255-3700 hope i've helped in some way :)
Mar 19, 2009 | Nintendo DS Console
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Ds lite
yes the new shell has this piece it's just not in the photo, it's in a bag not seen in most photos, you can replace this for about $25.00, or use a repair service on ebay
Aug 25, 2008 | Nintendo DS Console
Broken Hinge
There are plenty of replacement cases available from a popular auction web site, if your proficient with a screwdriver and have a lot of patience then you should be OK. Take great care when refitting the top screen ribbon cable (and taking it apart in the first place), the WIFI arial cable is awfully fiddly as it needs to be threaded under the slot 1 cartridge mechanism and finally take great care refitting the bottom case as plenty of people have reported snapping the plastic part of the power switch when reassembling. I reckon a first attempt should take 1-2 hours so clear the dining room table and don't forget to buy a tri wing driver when you get your replacement case if you haven't already got one. Best of luck.
Mar 12, 2008 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo ds hinge fix
Well, you can buy a hinge from a lot of places, but the wire that broke, you are going to have to try and fix the wire, get it connected again so that it will work. The only other solution is that you will have to send it in to get fixed.
Aug 08, 2007 | Nintendo DS Console
Nintendo DS Console Logo
187 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
