Question about HP iPAQ H2215 Pocket PC
Bluetooth initilizing problem
When I try to turn on bluetooth, it brings up a window saying BTTrayCE- Bluetooth could not be correctly initialized. When I go through bluetooth manager, it brings up another window saying: "The bluetooth Radio failed to turn ON due to insufficient driver memory available. You must perform a normal reset before you can turn ON the bluetooth radio. I have done a rest, and done it several times. I have the latest update for HP. I've also tried to clean up background stuff using a software called: "Clear Temp" I cant afford anything else right now. Please help. I believe this has been a problem since 2004.
  • HP Master
  • 3,422 Answers
Broken for 13 years. ok
what OS, ? XP?a the 100% dead OS? that?
what HP PC? full model name, like DV6-1234us.(full)
what blutooth radio, is it 13 years old too?>
what size memory is there, (cp +system)
then look in task manager see memory usage and free mem.
then go to startup folder (msconfig) and get rid of all memory hogging software in there, most are useless
many are, like this.
Adobe update nag
Nvidia update nag
xxxxx update nags. (all useless and memory waste big time)
ccleaner nag ,etc ((does auto cleans so, may be useful)
I only allow my , protectors there, AV and Malwarebytes, etc.
does the RADIO work on other PCs' be like 1st step
Posted on Apr 15, 2017
4 Suggested Answers
adib
  • 450 Answers
SOURCE: HP HX2110 wireless connection
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
Posted on Sep 11, 2005
SOURCE: bluetooth problem
often i find that programs are to blame for using lots of memory. a hard reset generally closes most of them but i use ClearTemp to remove the registry dregs and unused shortcuts. http://www.pda-ppc.com/download/utilities/content/cleartemp.html hope that helps!
Posted on Jul 27, 2007
nliwilson
  • 114 Answers
SOURCE: HP ipaq 5550 - Bluetooth error
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Posted on Aug 23, 2007
How to activate Blue tooth
I dint write it but i found it somewhere but you could try it and see if it helps.
First on
the radio you are going
to have to press menu
and then click on phone.
That should bring up the
bluetooth menu. Hit the
button that says "activate
bluetooth" or turn
bluetooth on or
something like that. Then
on your bluetooth
enabled cellular phone,
you need to turn on
bluetooth and turn your
visibility on. Search for
devices. Click connect
and then you're going to
have to create a passcode
for them. First enter it in
your phone, and then
you're going to have to
enter it in your car. Then
it will be paired and you
should be all set to go!
Note: the car has to be
running initially for this
pairing to work. Hope
this helps!
Mar 28, 2013 | Car Audio & Video
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
China N95 bluetooth not working
change the setting of the blue tooth from "hidden" to "visible to every one"
Sep 10, 2009 | Nokia N95 Cellular Phone
Bluetooth BTTrayCE - Bluetooth could not be correctly initialized
why ask here, like only a hand few of persons use these now.
its like, why not get used cell phone and play there? upgrade to that.
here is the official hp suport.
there is no HP product support page for legacy devices (retired)
but the HP forum guys, may have 1 guy that tell remembers so long ago.... long long , ago.
here ill type for you THERE.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=iPAQ+H2215
Sep 27, 2017 | HP iPAQ H2215 Pocket PC
Add bluetooth to lg rumor
you may have to reset the settings on the phone to correct these issues
Dec 22, 2008 | LG RUMOR Cellular Phone
Wont initialize bluetooth
First make sure your blue tooth is 100%charged, go into the bluetooth settings and make sure it is registered on the device
Jul 16, 2008 | Insignia Sport MP3 Player
BLUETOOTH! HELP
Go to the start menu, and select Settings. Select Connections from the bottom tabs and find the Bluetooth icon, and click on the bluetooth icon. Select Mode from the bottom tabs and check box that says "turn bluettoth on"
Jan 21, 2008 | Dopod D810 Smartphone
HP iPAQ H2215 Pocket PC Logo
115 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
