Question about Brother MFC-7820N Printer
Back cover open will not go away ... even though back cover is closed!
    Problem Solver:
  • 7 Answers
This is a common problem with the Brother 7820 printers. If you open the back cover, there is a black tray in front of the fuser roller that falls back. That black tray has an arm on the inside on one side that triggers the back cover open message. try pushing that tray up firmly against the back with the back cover open and see if the message disappears. If it does, try taping folded paper to the rails on inside of the grey back cover. The verital plastic rails are what push the black tray into the printer. By taping the paper on you are adding depth to them which will push the black tray further into the printer. If this doesn't work and you cannot get the message to go away from pushing on the black tray, there may be a problem with the trigger. If this were the case I would replace the printer. You can find the 7820 refurbished for $99 online. Just google 7820 refurb.
Posted on Apr 30, 2009
  • penzance13 Nov 10, 2010
    We had the same problem but nothing worked but then found the following.
    You will see the small black arm that is springloaeded it has 2 positions it can be in on the chute. It NEEDS to be on the 1 closest to the right so all you do is move the arm to the right and it slots into the correct position.
    Hope this helps
Incorrect "Cover open" indication
Hi, the cover sensor may have gotten stuck. So, even though the cover is closed, it's still sensing that it's open. Here's a link on what you can do to remedy the problem. http://bit.ly/9UYvzL . Hope this helps
Mar 10, 2010 | Lexmark X3470 All-In-One InkJet Printer
I have a printer phaser 8500DN that says close the front cover even though the cover is closed
open ypur back end of your printer and check fuser asembly.
reattach it.
then restart printer
Mar 31, 2008 | Computers & Internet
Error message 'top cover open' even while cover is closed
When the printer is used often, and ink and dust accumulate inside, the detector switch will sometimes get stuck and won't be depressed by the cover correctly. Open the cover and look right next to the sticker. There is a small rectangular hole with the switch. Use a very thin tool like a small screwdriver or paperclip bent open to push the switch inside the hole to the back of the printer. Do NOT push it just down! You *must* move the switch away from you. Hold the switch in this position and close the cover. Carefully pull out your tool from the gap.
Jan 28, 2010 | HP DeskJet 5652 InkJet Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Brother (photocopier, fax and scanner machine) says << back cover open. close back cover>> but the back cover (or at least what i think is the back cover) is closed. I even opened and closed it...
I have fixed this problem on my 7820n printer by brother.
open the back door, then inside there will be a black colored other kind of like door that pulls back away from the roller. on this inner door is a black long thin plastic lever that runs from about the center of the inner door to the right. on the right end of it is a lever that slides along a curved increase on the right side wall. when both doors are closed this right end of the rod or lever moves up to close the gap between what is the sensor. this long thin plastic rod had snapped out of place and when i snapped it back in making sure the spring was correctly installed on the left end of it and the middle part of the rod slid correctly in its groove...the right end of the lever correctly closed the gap on the sensor (when both doors are closed) and the back door open error went away.
So that's how you really fix it!!!!
James Hilliard - Totally super awesome guy! hee hee
Oct 27, 2009 | Brother MFC-7820N Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
http://www.fixya.com/support/t150137-one_more_person_back_cover_open_problem
Oct 24, 2008 | Brother MFC-7820N Printer
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC-7820N Printer Logo
520 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
