Question about Husqvarna Garden
I am having problems with my husky 142 with the .043 gauge bar
I have been having troubles finding the right bar for my 142. The saw says to use the .043 gauge bar. does anyone know why I muse use that bar or can I use the .050 gauge bar and chain on this saw.
Have been running saws for over 20 years and have found you can run pretty much any pitch chain on any saw (as long as the lengths matre up)
think about what you are going to be mostly cutting tho. if its softish wood get a chisel type chain.
have fun
Posted on Apr 15, 2009
I would find a lawn and garden shop that repairs chainsaws. Take your saw there and they should be able to get you the correct file.
Dec 02, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have husky 435 and want to put a 14" bar on the
Most all brands of chain saws will except one size smaller and one size bigger than what came with the saw. You just have to make sure the bolt holes and the hole for the adjustment pin match the origional bar.
Aug 26, 2012 | Garden
Hi what size bar do you reccomend for a husky 444 se
They were offered with 13,15,18" bars, most were sold with 15" .325 pitch 058 gauge part no. 508912164 bar ans chain 501840464.
Regards
Sep 12, 2011 | Husqvarna Chain Saw 20" Bar
I have a husky 235 (e = ?) & it has been very troublesome for me. My little 3000 Echo saw i purchased in 1995 (& have had refurbished once since then) outshines the husky reliability-wise. On the...
The oiling on this model has been an issue for a long time, the first and main problem was distortion of the bar pad due to heat from the muffler, and the ommision of a metal strengthener in the pad itself, what happens then is as the bar nuts are tightened, the bolts try to pull throught the bar pad, this creates a bulge around the bar bolt and causes the delivery tube to collapse, there was a later crankcase with steel inserts around the bar bolts to prevent this, and an updated delivery tube, you can tell when this has happened as the oil drips onto your shoes rather than going onto the chain, let me know it you need any more advice or i have not explained this very well, what has the dealer said about the oiling problem?
Apr 15, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
An earley 1984 husky 34 delux chainsaw bar has 320855 plus the number 120 under it
The Husky 34 was a badge engineered machine, it was actually manufactured by Skil under licence, it ran a 3/8 low profile chain ( 91sg ) 050 gauge, sorry cant remember the drive link count,after market bars and chains are still available from Oregon ( Blount ) it has to said it was not the best hobby saw going.
Jan 23, 2011 | Garden
I HAVE A 235 16"
A Husky 445 has a compression release (about the same bar length) which gets around this difficulty. We have a 435 Husky that has the same problem--your arm needs to be in pretty good shape to pull them through. We have found that the saw needs only one pull with the choke full on to be able to start on the second or third pull. Back the choke off about half to make the following pulls. Other than replace the saw, not much help I'm afraid.
Nov 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
What is the longest bar i can go on my 455 rancher saw ?
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 372 xp gas tank not venting has a new gas cap did not work
I looked at a 2007 IPL, your saw has a separate fuel tank vent. Husky is terrible about providing a nomenclature and you may need help from your local Husky dealer to identify components.
Find your "Illustrated parts lists" here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Nov 14, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
157 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
