Question about Kenmore Sewing Machines
How to fix the timing on a sewing mach Kenmore Model 385.16227300
I have been told my machine is out of time. I would like to know how to fix it myself.
  • radcal May 11, 2010
    First, you should determine if it is really out of time. Many people use timing as the reason that a machine won't work and it isn't the problem at all. If the needle to hook timing is incorrect the hook passes the needle below the eye. To check, thread the needle, remove the needle plate and rotate the hand wheel. If the thread is above the tip of the hook as it passes the needle the timing is most likely incorrect. Different machines are adjusted in different ways. There isn't a generic method for all machines. Please identify the model and maybe someone here will know it specifically.
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Kenmore Sewing Machines
Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Kenmore 15358
Timing on a brother sewing maching LX-1120
The timing is set on the lower shaft on the left end. Needle bar rise is 2.5mm. Check your timing belt tension to prevent this in the future.
Jan 25, 2009 | Brother LS-2125 Mechanical Sewing Machine
Broken belt
If you are having problems finding the correct belt, sometimes the stretch belts work great for these situations. You can find many of them on ebay.
Nov 14, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing maching model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Nov 10, 2008 | Kenmore Sewing Machines
Problem with my machine
If you're not picking up a bobbin thread, it's either a timing issue, or the hook/needle clearance. Usually, with the hook/needle clearance the skipping stitch problem will be intermittent. If it's a timing issue, it may not pick up the bobbin at all.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
117 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
