Question about Sony STR-D865
What power rated speaker shoud I use with my str-d865
I have a STR-D865 and do not have the specs on the output power. I need new speakers and do not know the power rating requied
  • 150 Answers
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Posted on Sep 14, 2007
SOURCE:
Sony STR-D865 Has no display or sound from any speakers
Fuses don't tend to blow on their own. The chances are that there is an overload somewhere. Caused by a shorted part.
There's a video on YouTube of this model and it is full of STK chips mounted on heat sinks. Check all of them out. Look for signs of damage such as burning.
May 10, 2018 | Sony Audio Players & Recorders
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Jan 02, 2011 | Sony str-4800sd stereo receiver with...
Sound quit and display shows PROTECTOR Sony STR-D865
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic.
1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 09, 2010 | Sony STR-D865
When i turn up volume on receiver it display protected and then i loose sound on my sony str-d865 receiver
That's a protection circuit in the output of the speakers. It indicates a short, or abnormally low resistance of the speaker itself. Disconnect the speaker wires from the unit, and see if the message goes away. If it did, you have a problem with your wiring, or the speaker itself.
Mar 13, 2010 | Sony Audio Players & Recorders
I turn it on and it says protect and wont play.
That model of receiver goes into protect mode when there is really
low
resistance or a short on your speakers/wires. It does it to protect the
final drivers in your amp. Does it do the same thing with all of your
speakers disconnected? If it doesn't then you might have a problem with
one of your speakers or wires. Check your wires for shorts in them
first. That may be the only problem. That model is designed for 8 ohm
speakers, but you can go down two 6 ohms safely. I have a STR -D865 that
has been running 6 ohm speakers safely for almost 3 years now. A way to
check your speakers out is to take an ohm-meter across the terminals on
them(with the receiver unhooked). They should read anywhere between 8
and 4 ohms. Check with the manual on your speakers to see if they
correspond. If the resistance is really low, you may have a short in
that speaker. it is also possible that if they are 4 ohm speakers, you
could have damaged the drivers in your receiver. I know the model above
mine, (the 965) has a 4-8 ohm speaker selection switch on the back. The
lower models were not designed to run 4 ohm speakers. Hopefully this has
been of some help.
Brad
Jul 18, 2009 | Sony STR-D565 Receiver
No audio through speakers and no light on volume dial of Sony STR-D865
unplug it back in went into safe mode it sounds like gotta watch those kids lol unplug from wall 10 min try pluging back in ok if not blow fuse inside
Jan 24, 2008 | Sony STR-D865
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
347 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
