Question about Samsung HL-R4264W 42" DLP HDTV
Groaning sound when powering on colors are wavy. power off and back on and picture is good for 1 hr or so.when powering off groaning does not stop. unplug power and it stopd
  • ESTEBAN MERINO
    ESTEBAN MERINO May 11, 2010
    if you are in MD send me an email i will help you solve this cheaper
    caypianan@yahoo.com
  • 147 Answers
The color wheel needs to be replaced. No way you can do this yourself. Would cost $300 - $400 to have a tech do it.
Posted on Apr 15, 2009
My Mitsubishi 73 in SDLP works fine for about an hr then turns green and starts jumping. I can turn it off and back on and it's good for about 15 mins. If its off for a while it starts within a hr
Hello. When the picture changes color after warming up, chances are that the color wheel is defective. If you get close enough, you might be able to hear a whining sound. If you do hear a whining sound, you definitely have a bad color wheel. Some color wheels are still available from Mitsubishi. Good luck!
Jul 31, 2016 | Mitsubishi Televison & Video
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung hdtv rear projection tv model#HCM4216W doesn't have any sound good picture though but does have some light waves in picture
the lack of sound is likely due to a defective audio output amplifier integrated circuit or IC for short, it needs replacing, the wavy lines through you picture is due to a defective filter capacitor in your power supply circuit, or may be due to the audio amplifier I.C drawing more current from your power supply causing a non clean power to be supplied to the video circuits, have the audio amp replaced first and note if the wavy lines are still present if so it is likely that some filter capacitors need replacing, to obtain sound you might be able to connect a external amplifier like your home stereo using the aux input and the sound output from your TV`s RCA jacks, this works well, let me know if you need further assistance good luck
Apr 27, 2010 | Samsung HCM4215W 42" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Low pitched grinding or groaning noise
Dan i recently had one of these in the shop and discovered a problems with blown capicitors in power supply.. however the low pitch groan indicates a fan or what is known as a color wheel. if this motorized part does not reach speed the lamp will not fire. replaceing the color wheel is not an easy task.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Samsung HL-R4264W 42" DLP HDTV Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
