Question about SanDisk Sansa e270 MP3 Player
Volume button my sansa clip volume does not working.Mainly increase volume does not working.
  • 11,896 Answers
You can remove screws, pull apart and clean contacts with cotton swab and rubbing alcohol. this should cure the problem. If this by slight chance didn't work, than it may be an electronical or programming error
Posted on Apr 15, 2009
Volume too low
"Turn" the thumbwheel clockwise to increase the volume.
Oct 01, 2013 | SanDisk Sansa Clip MP3 Player
Sandisk sansa clip mp3 player volume too low
'Turn' the thumbwheel clockwise to increase the volume.
The volume on my sansa clip 8gb is too low. I have tried the solutions given on here for this problem but they don't work as there is no option under settings for either volume, or reset. The only option...
Found this in one of the other posted problems, and it worked for me. kanturner
  • Rank: Apprentice
  • Rating: 96%, 18 Votes
My 8Gb Clip did the same after a firmware update. Apparently it's due to new EU regs about MP3player volume limiting. To fix select 'reset all' (note any settings you want to re-set later), after reset, select your language and then set region to 'Rest of World'. Sorted!
May 09, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2Mb Volume control will not increase volume ... only decrease.
You should update new firmware at http://forums.sandisk.com/sansa/
If the device still has problem, check the volume button.
Good luck
Feb 06, 2010 | SanDisk Sansa Clip MP3 Player
The volume control is frozen on the lowest level.
The manual gives next steps to setup the volume:
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
Manual in pdf format for the Sansa Clip:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
I cant turn volume up on my sandisk clip
My problem seems to be a damaged volume button. Once I tour the volume down (the down button is fine) I could not increase back de volume.
This is a palliative sollution. You need to reset you Sansa clip to get the volume set to the "middle" of the range. To steps are:
1) clique in the "home" button.
2) navigate to "settings"
3) select the "Reset All" option and confirm it.
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
Volume button stuck
i think you cotinously keep on increasing and loweing the volume in you sandick mp3 player
take it to the repair electronic shop
the rubber below your volume key get dispalced sometime or get stuck due to which it doesnt work.
dont worry i hope it can be repaired
Dec 11, 2008 | SanDisk Sansa Clip MP3 Player
Volume button seems to be stuck
The volume bar of my mp3 seems to go down, I dont know what to do??????!!!!!!>>>>
Jul 16, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2 gig computer doesnt find
This is the method that will force Windows to recognize the Sansa: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e270 MP3 Player Logo
75 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
