Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5 STORE N GO - 97538 Hard Drive Logo
Susan Reed Posted on Sep 09, 2013
External hard disk
I didn t get a disk with my external hard drive
Andre Pratama
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Sep 12, 2013
Andre Pratama
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
9925
Points
57
You should not need a disk to get an external hard disk initialized. Did you try to plug it into your PC and see if it detects it?
Clicking problem and laptop didn`t recognized my external
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 • Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
1helpful
Hello. I have a laptop hp, but i found out that the hdd is toshiba mk6465GSX.. Today i was working in my office and it suddenly crashes and the board didn't see it for booting..in fact the hdd is...
You can try placing it into an external hard drive caddy (your internal plugs into it)
The device will plug in usb 2.0 and recognize as an external drive.
If the drive is unrecognizable, than unfortunately it has physically failed and costs to recovery data are very high.
Always have 2 forms of backup for all data.
Hello...after moving pc and take of power of WD Elements 400, it didn't show up anymore in the My Computer screen and doesn't seem to work...no sound, just the burning blue light..what to do?
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
1helpful
2answers
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
2answers
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
External hard disk
If you have a Firewire port in your computer, then it is better to go for an external hard disk with a Firewire interface. Otherwise, a USB external hard disk will do the job.
Below are some links which might help you take a decision:
Link 1: http://www.techsaver.com/2008/12/bargain_hunt_external_hard_dri_1.php
Link 2: http://reviews.cnet.com/hard-drives/
Link 3: http://www.consumersearch.com/external-hard-drives
Link 4: http://www.pcworld.com/reviews/collection/1650/top_10_external_hard_drives.html
Computer freezes cause of WDexternal hard disk
does your wd external hard disk use external power or bus power.... if it uses external power this effect could be due to feeding of power from the external power to the usb port...
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
