Question about Kitchen Ranges
Oven model# 66575822000 came with home, after setting temp then pressing start you hear a click but the usual flame turn-on sound does not sound. nothing happends no gas smell this problen is intermittent. i don't have an owners manual please help god bless and thanks
4 Suggested Answers
  • 20 Answers
SOURCE: Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
Posted on May 21, 2009
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
  • 2287 Answers
SOURCE: When you turn the knob you dont smell gas, don't here the click of the igniter, but would like to light the oven manually. Can you help me please.
you can't manually light the oven with a match anymore,you have an electronic ignition in the oven or an ignitor part number 5303935066 and it's around 60 dollars.you have to remove the racks,remove the floor of the oven and then remove the cover and you'll see the ignitor in the back screwed to the tube usually with two 5/16 inch screws. set the oven to bake on 350,if the ignitor glows but doesn't light in 40 seconds it's bad,if it doesn't light at all you can unplug the ignitor and check it with a meter for continuity but most likely you have a bad ignitor.wet a paper towel and wet the two screws,they will come out easier,you can't use wd or anything like that because it will smell when you turn the oven on so use water, if you can see where the disconnect is to unplug the ignitor unplug it or when you get the screws out cut the two wires close to the ignitor,the new ignitor comes with ceramic wire nuts so you can connect the two wires you just cut to the new ignitor,the wires on the new ignitor will be long,you can screw the new ignitor on,leave around 6 inches of wire on the new ignitor so the wire connectors will be away from the tube and not up near the floor and if you have the ignitor screwed on you can see how long to make the wires,cut the wires and strip the ends on the old and new wires and wire nut them together.then turn it on to bake,when the ignitor starts to glow it sholud lite the flame in less than 40 seconds.hope this helps you out.one more thing don't touch the piece of the ignitor that's inside the metal bracket,they break very easy.good luck and have a great holiday.
Posted on Nov 21, 2011
The fan is working bt the oven isnt getting hot
I assume you have already checked the gas supply by turning on a burner on top.
Do you smell gas when the oven first tries to light? If the flame sensor isn't picking up a fire on the oven burner within a few seconds after the igniter is supposed to start firing, it will shut off the gas valve. The first thing to check is the oven igniter. Can you hear it sparking (repeated snapping sound until main flame starts)? The sound may be drowned out by the fan, so hearing it would only verify that it's making sparks; not hearing it doesn't tell you anything unless you were able to hear it before the problem started. If you had a major spill in the oven recently, it's possible some residue made its way to the igniter or pilot flame tube and is gumming up the works.
The next items to check would be the oven gas valve and thermostat.
Nov 12, 2010 | DeLonghi DEFSGG36 Gas Kitchen Range
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
The stove does not heat up
Check the flame of the gas jet and make sure they are unobstructed and the flame is a steady blue. See if changing the temp affects the flame. It sounds liKe your temperature sensors might not be working. They are not that usually very expensive but trouble shoot the little things. If you have a knob control pull it and make sure that the inside is not broken just to be safe. The sensor is s usually at the left rear panel of the oven. Make sure it is intact. The other regulators would be under the floor of the oven where the gas jets are. good luck.
Nov 15, 2009 | Amana AGR5835QDS Gas Kitchen Range
The dial on my Avanti 24" oven is hard to determine which way to turn. When I hear the clicking sound, as the burners do, next I hear the lighting, whoom. Shall I start it at a low temp and then in a few...
It sounds like you are having an excesive buildup of gas pre-ignition. You should hear no "Whooom" sound.
The ignition assemble likely needs to be cleaned of rust, dirt, grease etc. That is the typical cause if improper ignition, gas buildup pre-ignition etc.
The problem of not staying lit is caused by either the flame sensor not sensing flame, (which may need to be cleaned or replaced.) or that the flame is simply being blown out by the air movement as a result of the sudden combustion of excessive gas build up.
So, to summarize, the ignition and burner assemblies need to be cleaned, and the flame sensor may need to be replaced.
Oct 12, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Jun 30, 2009 | GE Profile JT910SASS Electric Single Oven
Problem with oven ignition unit
It works...But I called to have the oven checked out. Thanks, tnf
Feb 19, 2009 | Kenmore Kitchen Ranges
I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Mar 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
