Ok fred you have loose socket in the LCD to main board or the flex ribbon wire thats connect the LCD and the main board! or if not work if you did that! change flex ribbon wire! and or the LCD.
Try charging the phone. The outside screen should indicate the charge level. If the outside screen is blank then the phone is likely to be faulty. If the outside screen works but the inside screen doesn't work, then the phone may be faulty.
If the inside screen and the outside screen is blank, the possible problem is the LCD flex cable. But if the outside sceen is on
but the large inside screen is blank. The large screen could be defective.
