Question about HP Compaq Presario V2000 Notebook
Compaq v2000 this laptop is about a yr old and it worked great up until 2 weeks ago. it starts up then goes to the loading windows screen then i get a blue screen of death. i tried taking the battery out and holding the power button down but nothing. i am currently running the harddrive test on it so far so good. when thats done i will try taking one of the ram sticks out (2x1gig sticks) anyways if that doesn't work i suppose its my hd.. can anyone shoot me the specs of the stock harddrive?
I had same problem. Peplaced harddrive.
Posted on Sep 15, 2007
    Sergeant:
  • 457 Answers
No its a software problem.....I believe you are using Windows XP. can you tell when it loads or starts to load it stops at the windows loading part only does it go near the boot screen ie; XP loading........like that or straight to blue screen. Ive seen this before its not a hardware its a software. Have you got the installation disk XP if so.....insert it in the CDrom and start the machine up from scratch. Allow windos to go through the rig ma role of installation until it cant go no further. Press "R" for console go to the DOS line and type chkdsk /p allow windows to repair the problem when done remove the disk and start up again.....if Im right it should go pass that nagging "loading windows screen"...I hope it works for you, you'll be elated.
Posted on Sep 14, 2007
SOURCE:
Hello, I have a compaq presario v2000 and when I turn it on it goes through the normal start up until it gets to the point of going to the sign in mode. Then it goes to a solid blue screen with white...
HI
thank you for using Fixya
i would like to inform that your problem is indicates 2 isuue
1 your Windows is not working properly repair windows if know that how to repair
2 RAM is not supporting
frist try to replace your RAM then Try to on hope fully it will work normaly
May 14, 2010 | HP Compaq Presario V2000 Notebook
Running home ed windows on presario v2000 (now five yrs old) windows loads but harddrive continues to run inefectually - cant access programmes etc - then screen turns blank after approx 20-30mins - hard...
Backup your programs immediately to a thumb drive or external HD. The hard drive may be on the brink of failing. You can replace a hard drive, it's your information thats on it that you may not be able to if it totally crashes!
Mar 20, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 won't go past welcome screen
try to insteret you cd recovery from your laptop box...
if you cannot, restore your backed up data...
if you do not have any backed up data!!!!!!!!!!!!!!!!!!
DANGEROUS,,, you will have to insert windows xp cd installiation then click the button that says Repair e.g F'' F;;
Aug 27, 2009 | HP Compaq Presario V2000 Notebook
My compaq presario v2000 turns on and loads up but it doesnt go to the login screen. it loads it but doent show up so it restarts
when it starts to boot Force it into bios mode and check the win operating system . sounds like you picked up a boot virus and windows is not in control of the system.
Jul 09, 2009 | HP Compaq Presario V2000 Notebook
Screen goes blank after windows loads
Hi there
If you tried in safe mode and still no joy you will have to perform a system recovery with the recovery disk you got with the laptop or the recovery partition, Please be aware that you will loose data.
Good luck
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
Screen turns black suddenly
Hi guys!
I think your problem is one of the following:
1- AC Device or Batteries.
2- RAM.
3- Graphic Card.
So, plz check them by order.
I hope this problem is solved.
Nov 04, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 power off unexpectedly.
There are quite a few laptops and towers (my e-machine) that is not compatible with service pack 2. However, they are compatible with service pack 3 release candidate 2. Down towards bottom of page, choose which language.
Apr 05, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
Blank screen
Plug and external monitor to it if that goes unfortunely the LCD in that lappy is stuffed...if not then something else has gone amiss come back here to tell us a bit more info.
Oct 02, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
