Question about Kenmore 24032\24036 Top Load Washer
I have a model 70 kenmore washer that will not spin or aggitate.
My Kenmore model 70 washer will not spin or aggitate. it simply makes a roaring sound as if it is trying to spin.
  • Kenmore Master
  • 8,220 Answers
Captain we have a problem with the hyper drive. Spock what do you make of it? Logically speaking I would say we is dead in the water. Bones what do you make of it? **** Jim I'm a doctor not a laundry attendant. Scotty give us an update: Aye captain the lid switch has failed. if we don't do something fast the funk will knock us all to our knees in the laundry room. What do you suggest Scotty? I say we take a look at the lid switch Captain. I have a model 70 kenmore washer that will not spi - 8f7d82e.jpgLogically captain we should check out this excellent page on clutch replacement which includes directions how to jump out the lid switch FOR TEST PURPOSES ONLY. Proceed Spock...and may the farce be with ye
Posted on Apr 16, 2009
Kenmore model # 110.23832100 Washer would drain but wouldn't spin or aggitate. Replaced coupler. Now will spin and agitate, but will not drain.
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
Jul 15, 2011 | Kenmore 23822 Top Load Washer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
175 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
