After a lightning storm that knocked out my landline phones, my printer, which was connected to phone lines for faxing, and left my sound buzzing, I have not been able to resolve my sound problem. I had to replace the printer entirely, and hooked up the new one which works no problem. Unfortunately, after trying to replace the sound capability with a new sound card, I still get a buzz, and the computer does not recognize the new hardware, as I do not get an installation wizard prompt after I secured the card in the bay.
I turned off the onboard sound in the bios. No help. Installed the software anyway. No difference.
Am resigned to what my tech friends have suggested - that I will have to replace the motherboard. If the new printer installed fine, why is the sound not so easily resolved? Will just buy the motherboard if there is no other solution besides what I have already unsuccessfully tried. If I've missed something, can anyone suggest the next step? I don't want to replace the motherboard if it's not necessary. Thanks.
Comments:
Apr 16, 2009
- Yes, I tried the speakers and computer system plugged into other power sources. I also have the computer audio connected to my stereo system. This system is plugged into a power strip competely different from the computer power strip. The buzz only comes from the computer source. I have connected the cable going into other aux jacks on the stereo receiver, and it doesn't matter which jack I plug it into, the buzz persists, although the other audio sources on my stereo receiver are fine. That led me to conclude it's the computer output. Anyway, I finally broke down and ordered a new motherboard, and one of my tech friends is going to help me install it. Hopefully this will restore my sound to normal . Will keep the community here posted. Thanks.
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,...
(More)
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet, ik trachte ook met opstartschijf.... Ik zie dat bios/cmos? niet opstart, op mijn scherm krijg ik enkele seconden "in power safe mode, press any key" ik probeerde al veel, batterij eruit gehaald en vernieuwd, videokaart gewisseld, scherm gewisseld, alle plug ins nagekeken,enz.... Kan iemand zeggen wat er aan de hand is en hoe ik het kan verhelpen, ik trachtte ook het oude geheugen teurg te plaatsen, dit zonder resultaat mvg Jan
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear...
(More)
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear during the day for the sun light i mean , the problem begins i closed the screen and the computre was running now the computre can not start unless to remove the buttery but can work normaly if connected other screen how can i solve this problem
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother...
(More)
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother board not sure which goes where. PC is a e machines T3624
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard...
(More)
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard drivers to download direct so i can put on disc to correct
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan...
(More)
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan amable de pasarmelo se lo voy a agradecer mucho.
