Question about Toshiba Televison & Video
Picture has widened
My picture has spread out wider and approx 1 is cut off on each side of the screen. (toshiba tube tv.) is there any way to fix it and narrow the picture so it all shows on my tv?
  • 56 Answers
There are alot of things that can cause this. In my experience the most likley culprit in an older TV is that an electrolytic capacitor in the horizontal circuit has gone bad due to heat. You will need to locate the horizontal section and check each cap. especially those near a heat source like a transistor or IC on a heat sync. Since TV's have dangerous lethal voltages I would only recommend doing this if you have experience and take the usual industry accepted percautions.
Posted on Apr 15, 2009
How to widen my curtis 42 inch flat sreen top and bottom
Some TV's have a zoom function others do not. The program you're watching controls whether the top and bottom of the screen have black bars and is not the fault of the TV. Widening the picture cuts off a lot of the viewable picture and distorts the image. Circles tend to be oval. If your TV has a zoom function, use it.
Jan 21, 2017 | Top Computers & Internet
Toshiba 61H70
Does the rest of the viewing picture looks like the picture below?b66a18b.jpg
Jul 04, 2008 | Toshiba 61H70 61" Rear Projection...
PICTURE CUTS OFF AFTER A FEW SECONDS
the inverter is the usual cause of that issue. You can get the replacement Inverter from www.tvrepairworld.com
Aug 23, 2012 | Sanyo DP42848 LCD TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
Toshiba 47WL T66
Correct, its problem of LCD Panel and will be replaced.
No alternate solution for vertical or horizontal lines in LCD Panels.
Nov 10, 2008 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Picture is too large for the screen, horizontally.
No my friend, there is a problem with the width circuit, and this would be in the pincussion correction circuit of the TV set. There is alot of high voltage in this circuit, and if you have no TV repair experience, play it safe and call in a tech to service this for you. there is not any adjust ment that will fix this. Good Luck
Apr 29, 2007 | Philips 32PT6441/37 32" TV
My Picture is wider than the screen
How much wider are we talking about? It is normal for all TV's to be a bit overscanned anyway.
Apr 18, 2007 | Apex Digital GT3215 32" TV
Televison & Video Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
