Question about Harley Davidson 2007 Harley-Davidson FLHX Street Glide
Lights dim when rpms up
I have a 1997 harley davidson flhtci,when it is idoling everything is fine,when i raise the rpms the lights go dim,where do i start to look to fix this problem
  • 130 Answers
ALTERNATOR
Posted on Jul 15, 2009
  • 40 Answers
Look for short to ground or bad ground amongst electrical components ie; stator and regulator; check stator / regulator outputs iaw electrical diagnostic manual. will need a multimeter or fluke equivalent.
Posted on Jul 07, 2009
    Sergeant:
  • Harley Davidson Expert
  • 284 Answers
Start by checking you're stator output, Put a meter on it in VAC ( Volts AC ) on the 2 wires coming out of the case ( on the left side of the bike ) run the bike General rule of thumb is 25 VAC for every 3000 rpm. ex: 25 @ 3000, 50 @ 4000, 75 @ 3000. On the older bikes as long as you're around 65 and up @ 3000 you should be good.
Posted on Jun 11, 2009
2005 harley davidson flhtci run switch replacement
Hi, Todd for this scenario you will need a service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jul 13, 2016 | 2005 Harley Davidson FLHTC - FLHTCI...
Harley troubleshooting
If high beam element is not burned out it should light but you say when you have it on there is no headlight but then you say when you switch to high beam you have a headlight but it dims. You need to clarify what headlight beam you do or do not have and if the elements are okay it sounds like maybe you have a poor ground problem at the headlight.
May 30, 2014 | 2004 Harley Davidson FLHTC - FLHTCI...
FLHTCI charging quit, replace regulator worked fine for two days then went out again.
Hi Anonymous, you need to do a complete charging system test, load test battery, regulator bleedback, alternator condition and output test plus condition of all wiring and connections. If you need a cheap ($6.50) service manual please visit website below:
Good luck
Mar 03, 2014 | 2006 Harley Davidson FLHTCI Electra Glide...
No start just clicks at starter 2002 flhtci
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a possible prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 05, 2014 | Harley Davidson FLHT Electra Glide...
Difference between Harley Davidson FLHTC - FLHTCI Electra Glide
Hi Anonymous, FLHTC is carbureted and FLHTCI is fuel injected. Good luck
Aug 19, 2013 | Harley Davidson FLHTC - FLHTCI Electra...
Where is horn relay on 2006 harley flhtci
Hi Richard, 1992 and later touring models, fuel pump fuses and relays will be behind the right side panel, everything else will be behind the left side panel. Good luck.
Apr 18, 2013 | Harley Davidson FLHTCUI Electra Glide...
2004 FLHTCI Oil pressure not stable
Put an oil pressure gauge on it and monitor it closely. Could be a defective sending unit showing low pressure when pressure is fine. Tapping may be spark knock. Harley did have problems with their fuel injection systems. Make sure you have the right oil filter and oil is at the recommended level.
Apr 27, 2009 | 2004 Harley Davidson FLHTC - FLHTCI...
Check engine light comes on
Hi Larry, not hard at all, but it's too bad you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Mar 29, 2009 | 2004 Harley Davidson FLHTC - FLHTCI...
Harley Davidson 2007 Harley-Davidson FLHX Street Glide Logo
185 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
Mark McGinty
Mark McGinty
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
