2004 GMC Sierra Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air blend door
2004 Gmc Sierra w/dual control heat. one side will blow cold air & the other hot installed new controller. same result air door actuator be the problem ?
  • 2 more comments
  • Anonymous Mar 12, 2014
    Is there a fuse that controls the blend door actuator
  • Anonymous Mar 18, 2014
    No hot air in 99dodge1500 Think the blend door does it have a vaccum switch
  • Anonymous Mar 22, 2014
    air is only coming out on the floor, it does not come out on defrost or midrange settings.
  • Anonymous Mar 26, 2014
    left side blowes hot air all the time where is the blend door on this gmc
honeymokey
Level 3:
President:
  • Master 3,113 Answers
  • Posted on Apr 15, 2009
honeymokey
Master
Level 3:
President:
Answers
3113
Questions
Helped
1023984
Points
7683
Replace the broken actuator.
  • Robert McKnight
    Robert McKnight Nov 12, 2013
    Where is the actuator located
1helpful
2answers
2004 Chevy Tahoe: I changed A/C blend door actuator on passenger side and it's still blowing heat on my driver side?
Does the vehicle have dual zone climate control, where the driver side and passenger side have different control? Sounds like a blend door issue on the driver side. Why did you replace the passenger side, was it blowing hot too when AC was on?
Passenger A/C blowing hot air in a 2004 GMC Sierra SLT.
Usually when one side is hot and the other is cold, and each side is controlled separately, the problem is a blend door not working.
The blend doors are usually controlled by small electric motors.
You might research "blend door" online and see if anything pops up.
2helpful
2004 GMC Envoy SLT, had to install a new battery. Prior to installation, dual air was working fine, now passenger's 2 vents are blowing hot air while dirver's side is cold. Need help
It is likely that one or more of the blend doors or their actuators are stuck. Before any repair action is done, try allowing the HVAC system to recalibrate itself. To do this, turn all HVAC controls and switches to their OFF or CCW postions, then disconnect the battery for about 10 minutes. Reconnect the battery, but do not touch any of the HVAC controls or switches for about 2 -3 minutes. If this does not cure the problem, the HVAC system will need to be diagnosed. Access to the blend doors and actuators may require some disassembly of the center dash area.
6helpful
No heat of drivers side blows cold air while passengers side works blows hot air just fine
Replace the door blend actuator behind glove box, approx $150 for part, Everyone I know with dual control on the silverado's have this problem.
A/c blows cold on passenger side, hot on drivers side
To correct this problem u will need to replace the air temperature control blend door and the electric blend door actuator inside the dash, contact your local dealer for parts, they are dealer only parts
6helpful
2answers
2004 gmc 1500 heat is only blowing on passenger side. driver side is blowing cold air.
sounds like you have dual zone climate control in your truck. Most likely the actuator that controls the temp door in the HVAC box
12helpful
2answers
2004 chevy avalanche with dual control system problem
this problem is caused in almost all cases by a failed actuator that moves the door insiode the heating/ac duct to change the outlet temperature, it is called the Air Temperature Control Blend Door actuator.
3helpful
My air blows hot even tho my climate control is on cold
U have a stuck air temp control blend door, either the actuator motor is defective or the door is warped and has jammed, one thing is that u must remove the dash to rcheck replace these parts.
1helpful
2004 suburban rear a/c only blows hot air
ase mechanic:
there are separate actuators for the blend doors. one for heat and one for cool. they work opposite and in conjuction with each other, if that makes any sense. ones open, ones close, for each different climate. sounds like the the cold one isn't opening in the rear.
Cold air comming out of right side duel control when heat is on
the blend doors have broken...you will need to remove the heater/ac box to replace them
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
