This is a virus activity which prevents to use command prompt on the infected machine, this virus is called PC-OFF.bat trojan which turns off or shutdown your computer when ever you try to use command prompt by any means.
The infected computer restarts on opening command prompt.
This PC-OFF.bat virus creates the following files
- password_viewer.exe
- bar311.exe
- photo.zip.exe
- pc-off.bat
at the following locations
- c:\windows\bar311.exe
- c:\windows\password_viewer.exe
- c:\windows\photo.zip.exe
- c:\windows\pc-off.bat
Another variant of the this virus is recognized as bar311.exe virus A.K.A. winzip123 which will have almost the same symptoms and when ever you boot your Windows Xp computer in safe mode it will say a message Thank You!!! Password:Winzip123
Let's find out the fix to remove this shutdown virus completely from computer.
Fix:
1. Open Task Manager by pressing
Ctrl+Shift+Esc, click the process tab and locate the process named '
password_viewer.exe' or '
bar311.exe' or '
photo.zip.exe' one by one and right click and select '
End Process'
2. Open Start Menu >> Run, type
regedit and press Enter key or OK button
3. Navigate to the following path
HKEY_LOCAL_MACHINE \ SOFTWARE \ MICROSOFT \ WINDOWS NT \ CURRENTVERSION \ WINLOGON
4. Locate the key named
Userinit in right pane
"Userinit" = C:\WINDOWS\system32\userinit.exe,bar311.exe"
double click and remove the text 'bar311.exe' from the above
OR
"Userinit" = C:\WINDOWS\system32\userinit.exe,photo.zip.exe"
double click and remove the text 'photo.zip.exe' from the above
OR
"Userinit" = C:\WINDOWS\system32\userinit.exe,password_viewer.exe"
double click and remove the text 'password_viewer.exe' from the above
Note: Please make sure after editing the above Userinit key value it should be only
C:\WINDOWS\system32\userinit.exe (as shown in the image below)
5. Navigate to the following path now
HKEY_CURRENT_USER \software\microsoft\windows\currentversion\explorer\advanced
Change Value of the following registry Key's :-
"Hidden"=dword:00000001 (1) - Change to '1'
"HideFileExt"=Dword:00000000 (0) - Change to '0'
"ShowSupperHidden"=Dword:00000001 (1) - Change to '1'
6. Navigate to the following registry path
HKEY_CURRENT_USER \software\microsoft\Command Processor
Find the registry key named autorun, right click and delete this key. The value of the key would be
autorun=c:\windows\pc-off.bat
7. Open notepad and type the following commands
@echo off
del /a /f c:\windows\bar311.exe
del /a /f c:\windows\password_viewer.exe
del /a /f c:\windows\photo.zip.exe
del /a /f c:\windows\pc-off.bat
pause
Save it as remove-pc-off-virus.bat and double click to run it. Or just
download this batch file here and run it by double click.
8. Search for bar311.exe OR password_viewer.exe OR photo.zip.exe OR pc-off.bat and delete these files where ever found on your computer.
9. That's it, Enjoy the pc off virus is now completely removed from your computer.
Please clarify. Does it turn off your computer? What does it do, if anything and what do you need?
