I am not sure of the location of the hd port on my magnavox 37 inch hdtv. i am hooking up my dvr and am not sure where to start looking.... it is hanging on the fireplace.
    President:
  • 1,779 Answers
You should have a Component Input with Red-Green-Blue, those three plug into Comp1, if not used. If they are then use Comp 2 .Dont forget your red and white audio, that goes into Audio In. If you use just the Yellow lead that will not give you HD.
Posted on Apr 15, 2009
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
I need help in identifying whether or not my magnovox is 720p or 1020p. The ID # is 37mf437b/37 and the serial # is bz3a0722610855
Google the model number--owner's manuals are available on the internet for free.
This model (37MF437B/37) IS A 1080P SET.
If you need more information or advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for free.
SD TECH
Nov 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No hd
you have to make sure you switch the tv input to the hdmi input, not the coax input, also , only the hd chanels will look ha, the rest will prity much look the same as befor
Jan 07, 2009 | Hitachi 51F500 51" Rear Projection...
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
Protron 37" HDMI not producing sound
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Mar 29, 2007 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
