Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Wont Turn on
When I turn it on it makes a few faint beeps and then red power light blinks 5 times. And even then I have to unplug it everytime for it to even do that.
  • CW8891 Dec 03, 2007
    I turn the TV on, it turns off immediately, and the power light will flash 3 times.  The power light will continue this patter of 3 flashes, 2 to 3 second break, and repeat.  Please help.  The darn thing only needs to last a few more months.
I had the same problem with the same model. I have a friend who knows someone with a repair shop. He has access to trouble shooting programs. The search came up with three possibilities, Q551 which is the H.O.T., D503 which is a diode attached to the shield around your flyback and C509 which is a capacitor right in front of D503. Hope this helps you and if it does could you let me know.
Posted on Oct 07, 2007
  • 790 Answers
Ok you have bad oscillation,you have defective parts!
Posted on Sep 14, 2007
SOURCE:
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
    I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
    Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
    REAR PROJECTION HDTV ISSUE
    Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
    These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
    Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
    Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
    Akai lct3201ad red standby light turns green then red again!
    Symptoms of a Defective or dying Power supplies on LCD TVs.
    1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
    2. TV not turning ON properly.
    3. TV turns OFF by itself.
    4. Needs to be unplug to many times to make it work.
    5. Humming or high pitch noise heard through speakers or at the back of the TV.
    I repair these power supplies. Write to [email protected] if you require further assistance
    Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
    RED LIGHT IS ON BUT IT WILL ON TURN ON(GREEN)
    Feb 18, 2009 | Akai LCT2715 27 in. LCD Television
    LG 42 LCD no sound or picture
    Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
    Jan 28, 2009 | Televison & Video
    Insignia tv will not turn on [ power up]
    I repair these power supplies. Write to [email protected] if you require further assistance.
    Dec 19, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    The tv wont turn on
    hello 2 blinks on this tv means you have this issue below
    PT-44LCX65
    2 blinks 5 secs you have your lamp cover open
    check for this
    hope this helps
    Dec 14, 2008 | Panasonic PT-44LCX65 Television
    Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
    3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
    http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
    Jun 16, 2008 | Video Game Consoles & Games
    Panasonic PT-47WX53 47" Rear Projection HDTV Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
