How to recharge/convert freon on a 86 ford thunderbird?
  • 400 Answers
The correct way would be complete retrofit which means changing the condenser, the receiver drier, the expansion valve, valve plates and compressor oil. then flushing the evaporator and recharge. There are shortcuts to this but not recommended. You can just remove the compressor, drain the oil, measure the oil and replace with polyolester oil. Then vacuum the system for a good 30 min and recharge. If you have the correct equipment you should do a flush and purge a couple of times. Hope this helps.
Posted on Apr 15, 2009
Where is the cord to charge the Freon in a 2003 Thunderbird show image
follow the AC lines until you find the service fittings...low side (chg) should be the larger of the two
May 08, 2015 | 2003 Ford Thunderbird
How can I do my own AC recharge on a 95 Ford Thunderbird V-8
jump the ac relay so its engaged that brings the low side press down then the freon will go in then reinstall the relay when ac blows cold
Jun 04, 2012 | 1995 Ford Thunderbird
Line that carries freon. What does it look like?
It is an aluminum line that goes from the firewall to the compressor--this is the low pressure or return line. There is a second smaller line that goes from the firewall to the radiator--this is the high pressure line. The system is charged using the smaller port on the larger, low pressure line. The port looks like the valve on a tire, but is larger. There is a similar port on the high pressure line, but it is larger yet, and your recharge hose will not fit on it. Please let me know if you have more questions, and thanks for using FixYa.
Apr 09, 2011 | 2002 Ford Thunderbird
Where do you add freon in a 2002 ford thunderbird
On top of the compressor, driver's side. On the cooling system diagram of the mechanic's manual, see #5.
Jun 18, 2010 | 2002 Ford Thunderbird
1996 ford thunderbird v6 3.8, cataylic converter
Past experiences with that vehicle weve had to replace both front and rear converters.Check with napa they sell a direct fit converter like the oem unit.
Jan 29, 2010 | 1996 Ford Thunderbird LX
My 86 thunderbird starts and if i keep my foot on the thorttle it stays running but dies when i take my foot off the throttle
I'd be thinking of changing IAC valve that controls your idle. Clean the port(s) out good with throttle body cleaner when you get valve off too.
Apr 16, 2009 | 1985 Ford Thunderbird
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
