Question about Sirius Audio Players & Recorders
Sirius satellite radio constantly shows "acquiring signal"
I recently replace the antenna for my satellite radion. The cable was broken. There was no longer any audio and the display shows "acquiring signal". The symptoms remain the same after I replaced the antenna. Checked the signal strength in the menu and saw that the signal strength was sufficient. Now, I intermittently get audio, but more so "acquiring signal". Called Sirius and they insisted that it had to be the antenna. I disagree. It is highly unlikely that both antennas would have the same problem. I read on Yahoo, tha the tuner could be bad. Any suggestions?
  • Anonymous Mar 25, 2014
    What is causing the static and turn offs?
  • 95 Answers
It could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Posted on Apr 15, 2009
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Jul 08, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
If it is reading "ACQUIRING SIGNAL" WHAT CAN THIS MEAN??
This typicall represents a failed antenna with either a loose connection or failed wire to the antenna. The "Acquiring Signal" indicates the receiver is trying to locate and decipher a signal from a sattelite. THe antenna is your first diagnostic. After that the receiver is the culprit. When your receiver is Activated or Authorized it is given a "key" to decipher the sattelite signals If it loses the "key" you can try and have Sirius reinitialize by contacting support. If they cannot send the signal and get the proper "Key" loaded its a defect in the receiver functionality.
Jun 15, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
I keep getting ''Acquiring Signal'', but a signal is never aquired
Try moving your Sirius radio antenna to a window that faces west. Signal goes through windows better than walls.
Aug 23, 2009 | Sirius Satellite Radio Audio Players &...
Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Jun 02, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Sirius Stiletto 2 constantly "acquiring signal"
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
May 04, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
2,174 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
