Question about Dell E176FP 17" LCD Monitor
HOW DO I GET THIS STUPID PADLOCK THAT KEEPS OPENING AND CLOSING IN THE MIDDLE OF THE DELL MONITOR SCREEN TO GO AWAY FOR GOOD?????
  • dandsweber Apr 15, 2009
    did not work - tried this before, any other solution?
  • Anonymous Apr 17, 2009
    dan I am having the same problem can not figure it out either
  • 744 Answers
Solution Steps For Computers Running Windows XP
1. Click on "Start" at the bottom left of the screen.
2. Choose "Settings"
3. Choose "Control Panel"
4. Double click on the "Display" menu option.
5. Click on the "Settings" tab on the display dialog box.
6. Move the resolution slider to a different screen size (e.g. 800x600, 1024x768).
7. Hit the "Apply" button and select "Yes" that you want to use these new settings.
8. Change the resolution back to your preferred setting. Hit "Apply" and "Yes" again.
9. You can also righ-click on a blank spot on the desktop and choose "properties" to get to the same screen in Control Panel and change the settings
Posted on Apr 15, 2009
  • jdthefixer Apr 16, 2009
    Dan,
    Here are two other possible remedies.
    This is from the Dell support forum - I was able to help another user with the fix I posted earlier. It sounds like your issue could be something different. I have not tried these myself. See these posts:
    >>Someone there turned the OSD lock on. You can unlock the OSD by pushing and holding the Menu button for 15 seconds. This should stop the padlock from appearing.<<
    AND.....
    Re: Padlock symbol in Middle of Screen
    >>The problem appears to be caused by dirty contacts in the buttons. The result is a short circuit, which fools the monitor into thinking that the button(s) are being depressed. If you have a simple understanding of electronics, you can fix this in a matter of minutes (at you own risk, of course).
    Unplug the monitor
    Open it up by removing any screws and/or snaps
    Get access to the button panel
    Clean the contacts with a brush and some isopropanol
    Put everything back together
    Try the easier one first......
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck.
Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor.
http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display):
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
Jul 07, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
I have a blue and white padlock keeps showing up in the middle of my screen. Blinks on and off for a while then disappears, then comes back. On and on, very irritating.
It sounds like the DELL Capslock indicator. It is a light blue square with a lock on it and a capitol A under the hasp. You may have a bad keyboard key. switch out keyboards and see what happens.
Good luck,
James.
If this was a help, PLEASE click on 4 thumbs up!!
Apr 25, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Padlock appears in middle of screen in an on and off way. help me get rid of it
the same thing happend to me shortly after i accidently spilled water on my monitor. Time to open it up and see if theres liquid in there. if thats not what happend to you your monitor may be going bad. check out the buttons maybe one is stuck.
Feb 22, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Padlock appears on screen
The padlock is an indication that the On Screen Display is locked. You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds.
http://support.dell.com/support/edocs/monitors/e171fp/en/controls.htm
Sep 30, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
I have this monitor,got it used at the goodwill, padlock problem and the control buttons (eccept for power) did not work. I tried every solution posted with no success. Then I got brave, I dove into the problem. 1) remove base, four phillips head screws. 2) remove the back, five phillips head screws. one in each corner and one behind the base mount, thus the need to remove the base. 3) carefully pry off the back, it snaps on, so take your time. I found a butter knife to be very helpfull. 4) The buttons are sodered to an electrical board whitch is snapped into place so carefully pry up from one side,again I used a butter knife. The wires are sodered to the board, they do not unplug. 5) Using a can of air, blow into each button and trying to clean out the inside them. I'm sure they should probably be replaced but we do what we can. 6) Put it all back together. 7) plug it in and connect it to computer. start working the buttons, at first I thought it was a lost cause but after about a minute I was able to get into the menue, scroll down using the arrow buttons and turn the lock off. A $300 monitor for 40 bucks. I hope this message gets to you before you give up. GOOD LUCK, GMAN8773
Sep 05, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Flashing padlock icon in the middle of the screen
When the icon is in the unlock position, hold down the Menu key (the far left button in the lower righht hand corner) on your monitor. This should bring up the menu. From there, you can reset the factory settings.
Mar 16, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
Dell E176FP 17" LCD Monitor Logo
420 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
