Question about Refrigerators
INSTALL DEFROST HEATER KIT
HOW DO REMOVE AND INSTALL THE DEFROST HEATER KIT RSW2700 MAYTAG SIDE BY SIDE
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Defrost for Maytag side by side
To access the heater circuit you must remove shelves from freezer, defrost the back panel with a hair dryer. Remove screws holding the panel in place and remove the panel. Defrost any ice on coil. This will give access to the heaters and defrost thermostat. If the defrost thermostat is deformed in anyway such as bulging at the molded part the chance is that that is your problem. Reading through the heater circuit with an OHM meter will tell you if the heater(s) are open. If you get an open reading replace the heaters. If this is above your capabilities call a service tech.
Posted on May 27, 2008
  • 2330 Answers
SOURCE: defrost heater does not cycle on
you didn't send the full model number,starts with 110.or similar,you have a defrost problem,it could be a couple of things so you need to read out some parts with a meter,you could have a bad defrost thermostat the timer or adaptive defrost board depending on model number,bad heater,if it has a timer you need to advance it by turning the middle with a screw driver until you hear a click and the fan shuts off in the freezer,now you have it in defrost,see if the heater is on,if it is you have abad timer,if it didn't come on check the t stat,if it has plug in connectors on the wires disconnect the t stat and plug the wire derectly to the heater or if you have to cut the wires cut them and bypass the thermostat,if the heater comes on then you know you have a bad t stat,also pull the wires off the heater and check the heater,if the heater is bad it's a good idea to change out the t stat anyway,if it has an adaptive defrost board check the tech sheet that should be behind or on the bottom kick plate,remove it and look it will tell you how to put the fridge into defrost,i think you push in the both door switches 5 times at the same time,if it doesn't go into defrost could be the board,you'll have to still read out the heater with a meter,also if you read out the thermostat it has to be cold,if it warms up it will read open but it still could be good,if you need any more help with this let me know and send model number so i can help better
Posted on Feb 19, 2010
Testimonial: "Would have helped to know where these controls are located. The refiderator is located in a close area and hard to move. The model begins with 106."
  • 794 Answers
SOURCE: I have a Maytag rsw2700
Hi Ruben_J,
Is the compressor running? If it does and the machine is not blowing cold air inside the freezer you may have a leak inside the sealed system and all the Freon has escaped. If there's no Freon, no cool. You will need to call a repair man to have the Freon be fixed.
If the compressor is not running, in order for the machine to get cold, the motor has to run.If the condenser fan (fan by the compressor) is running and the compressor is not running then you have one of a few problems. Either the motor is not getting power and that's why its not running, or its getting power and the windings inside are shot and that's why it's not coming on.
Another thing that you can also check is the condenser coil. The Condenser Coils on your Refrigerator is where the Freon gets put under pressure, therefore causing them to get warm. In order for your Refrigerator to run efficiently these coils need to be able to dissipate the heat. If the coils are covered in Pet Hair or Dust, this will cause the sealed system to overheat. When the coils can't get rid of the heat created by the sealed system, the compressor will not be able to run.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 16, 2011
Maytag fridge RTT1900DAE - need instructions/diagram to access defrost heater, defrost timer, and defrost thermometer, so I can test them all. Haven't been able to find anything helpful using Internet...
defrost timer should be in the refrigerator side behind the temp control knob, defrost heater and thermostat should be located in the freezer compartment behind the cover plate for the fan. Just remove your shelves and you will see the screws holding the cover plate on, remove them and you will see the coils and fan. Thermostat / heater are at the bottom of the freezer coils
Sep 17, 2013 | Maytag Refrigerators
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
I need to change my defrost elements in my side by side Maytag but cannot locate them. Where are they in the fridge.
located in the freezer side behind the back plate. the elements ? there is only on and it calrod type and usualy not bad . ck the defroat thermo first . and some of these you must buy the heater with the thermo . as a kit . .. hope this helped mm feed back pls . and thanks for using fix ya ..
Oct 21, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have maytag msd2650keu freg. and defrost doesn't work I checked the deforst by a meter it has resistance. what is the next step to check?
i would first replace the defrost terminator this some time cks ok but the temps can be way off . if this does not solve problem replace the aditive defrost control lacated in the top of fresh food side . . the heater and thermo are sold as a kit . heater does not fail but terminator is very common .. mm hope this helps ..
Aug 18, 2010 | Refrigerators
Freezer is cold but fridge is not
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
tygf
May 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Have a Maytag MZD2766GES Side by Side Refrigerator, somehow it just stopped working. The freezer part is just a little cold but the other side is not cool at all. What can it be?
check the freezer compartment, remove the shelves remove the cover in the back if the condensing coil is frozen solid your adaptive defrost board or defrost coil is bad. a temporary fix is turn off refrigerator, defrost coil ( I used a space heater). turn refrigerator off . you will need to do this every third day until adaptive defrost board is replaced. to check defrost coil check with ohm meter It should have resistance. this website should give you the gory details http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 15, 2009 | Maytag MZD2766GES Side by Side...
Freezer and refrigerator not cooling
No not likely this time it is most likely the Adaptive Defrost Control located inside the fresh food compartment, part number 61005988 You also should check the defrost heater and defrost thermostat that comes as a kit located inside the back of the freezer compartment. Thanks, Sea Breeze
Aug 27, 2009 | Maytag MZD2766GES Side by Side...
Freezer frosts up and stops cooling after approximately 2 weeks GSS201EPHWW
AUTO DEFROST IS BAD REMOVE FREEZER BACK PANEL CHECK HEATER CONTINUITY WITH REFR. UNPLUGGGED IF HEATER BAD ORDER HEATER KIT FOR YOUR MODEL
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag RSW2700 Freezer cold Refrigrator Warm
Check for excessive frost build up in the freezer on the back panel. This would indicate that you have a defrost problem. One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, measures open (bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Apr 11, 2009 | Maytag Freezers
May 25, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
524 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
